How does this sound system sound to you? :P
Hey everyone, well I changed out my headunit to a Pioneer PREMIER flipdown headunit the one with like dolphins and shizit, and i change dout my stock speakers to the Boston dual with tweeter combo ones, all 4.. the head unit was about $350.00 and the speakers all together were $800.00 pretty expensive.. and I am thinking about getting the Rockford Fosgate P110S4 Punch Stage 1 10" 4-ohm subwoofer... 2 of them, and I am building a "Underseat" storage for them.. but now this, I dont have ANY IDEA what type of AMP to get.. for this all.. Im thinking of building a custom amp rack also to go in the hatch area... so yeah, help me out, im a total NEWB to all this, someone gave me a link to a site that tells all the info on "OHM" and all that stuff, but i have NO IDEA what there talking about .. lol, anywho, please help me out once again...
or hey ,maybe ill get this deal, its $320.00 for Rockford Fosgate Bass Package
P4002 2-channel car amplifier
Two P210S4 10" 4-ohm subwoofers
Here is the details:
Details:
» package includes Rockford Fosgate's P4002 2-channel car amplifier and two P210S4 10" 4-ohm subwoofers
» 100 watts RMS x 2 at 4 ohms (200 watts x 2 at 2 ohms)
» 400 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
» variable high- and low-pass filters (40-400 Hz at 12 dB per octave)
» variable bass boost (0-18 dB at 45 Hz) with wired remote control
» Tri-way capable (Tri-Way Crossover required)
» MOSFET power supply
» CEA-2006 compliant
» preamp-level inputs
» preamp outputs
» fuse rating: 30A x 2
» 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 11-11/16"W x 2-7/16"H x 11"D
» warranty: 1 year
P210S4 Stage 2 10" 4-ohm subwoofer
» molded polypropylene woofer cone
» 60-ounce magnet
» power range: 50-200 watts RMS
» peak power handling: 400 watts
» frequency response: 20-200 Hz
» sensitivity: 86 dB
» top-mount depth: 5-3/8" (without removable magnet cover; depth is 5-5/8" with cover)
» sealed box volume: 0.65 cubic feet
» ported box volume: 1.25 cubic feet
» warranty: 1 year
Is that good??
Details:
» preamp outputs
» warranty: 1 year
» 60-ounce magnet
» warranty: 1 year
Is that good??
Originally Posted by NewMexicoxBPhatBoy
And .65 is exactly? . . .Im not putting that box in, im making my own, you mean the sub wont fit in that box?
damn, so than I most likely need to go with the PUNCH stage 1 8" or 10" sub?
I used to have it in my fiero, with a .3 sealed enclosure. It his OK for an 8". IF you are limiterd on space, I would suggest the Image Dynamics ID8v3 D4. it is an 8" dual voice coil sub, and I couldn't ask for more form it.
Here is a link to my build thread on it for my Fiero. When I do get my scion, I will be using an Image Dynamics sub, personaly this is the best sub I have ever heard for clearity.
http://www.fiero.nl/forum/Archives/A...-1-051244.html
LoL.. oh, well can someone help me out? Like help me look for a system for $750.00 (Subs, amp) stuff like that, just mainly 2 subs and an amp, or maybe even 3subs.. I think the more the merrier (And louder) right? lol.. anyway help me out, If I cant find anything for under the seat, ill just get something for my hatch like everyone else.. I guess
well I have 2 8's under my seats and 2 12's in the back.... you can do just 2 8's under the seats and do an amp in the rear hidden cargo area
I can recomend someone to help with the under the seat boxes....he built mine
I'd suggest waiting untill the middle of October and getting 2 of Elemental Designs SQ10's... it's a 10" woofer that's only 3" deep and only requires .3-.5cuft sealed.... put one under each seat and put a ED Nine.2x (600watts) on the pair and you'll have an awesome substage!!!
not to mention, you get a great discount for being a Scionlife member... here are the forum prices:
CLICK HERE
also, Elemental Designs has a great forum with LOTS of stereo information and help... Here's the address
www.icixsound.com
CLICK HERE
www.icixsound.com
well, when you can push 300-500 watts though a single one... that's gotta tell you somethin... I'm not saying everyone should put 500 watts to one, but if you know what you're doing, it's very possible..
Thanks Sci_Tc_Guy.. that helped alot and those subs are nice, but Sciond, are you saying that i will be using WAYY more power to my ride if i use these? or sumthin.. and if so, if i do decide to get these.. what would i need so I can have alot of power to power that "High-powered" compression thing?
2 SQ10 SVC 2ohm subs and an Elemental Designs Nine.2x. Wire the subs in series for a 4ohm mono load and you'll get around 300 per sub which would be perfect and would pound pretty dang good.... not to mention sound excellent
All I am saying is when you deal with drivers and you have these ones that can handle a lot power you have something called power compression which means simply stated you will need a lot of baseline power to move those drivers. You can do the same with less power with drivers that do not need as much baseline power when dealing with a basic system. One thing to pay attention to is sensitivity which let you know the effeciency of the driver and try to match all them as closely as possible
