How to install air/fuel gauge?
Old Apr 12, 2005 | 06:46 AM
craE's Avatar
Default How to install air/fuel gauge?
i just got an auto meter gauge for air fuel ratio and want to know what wire i have to tap into on the o2 senser there are 4 wires one white one blue and 2 black any ideas?
Old Apr 12, 2005 | 07:41 AM
krazykoo's Avatar
hey wassup, i have never installed the gauge on a tc, but i have installed them on a couple of hondas. i had to use the white wire. the colors are the same as my hondas, so the white one should be the right color to splice it in!!!
Old Apr 12, 2005 | 04:51 PM
craE's Avatar
thanks for the reply but im really not sure on just clipping wires on a new car i think im going to toyota today if i dont get an awnser thanks though, you may be right!
Old Apr 12, 2005 | 06:25 PM
retrodrive's Avatar
Just to let you know that AF gauge is absolutely useless. It is too slow reacting to show whats really going on and it does not show exact numbers also. If you trying to install one for a purpose of monitoring your AFR and not just looks, you would need a wideband setup.
Old Apr 12, 2005 | 11:15 PM
craE's Avatar
im just going for looks but could some one please tell me what wire to tap into, i went to toyota today and there "master tech" could not awnser my question so some one help me please.
Old Apr 12, 2005 | 11:23 PM
dgHotLava's Avatar
moved...
Old Apr 12, 2005 | 11:34 PM
ScionON18s's Avatar
its the black wire...u have to strip it and its the wire inside that one.
Old Apr 13, 2005 | 01:32 AM
craE's Avatar
there are 2 black wires and im pretty sure those arnt the ones the black wires are usually grounds or nuetrals
Old Apr 13, 2005 | 01:38 AM
engifineer's Avatar
True, the resolution on the O2 sensors is not very high.. meaning you wont get very accurate readings... the ECU uses that data as more of a trim. The wideband setup will give you much more precise data.... but for simple in range/out of range monitoring, and for looks, the AF gauge will do ok. If you are looking into serious tuning and FI.... go for the wideband for sure!
Old Apr 13, 2005 | 01:41 AM
engifineer's Avatar
Aren't those "master techs" great?? My dad loves em... he gets their business daily If they actually knew how to troubleshoot a problem instead of just taking readings from a scan tool.. they could tell you since they have a shop manual right there! I dont have the manual... and am too lazy to grab the multimeter and go take some measurements for ya to see which wire is the output.... sorry I'm not of much help right now!!
Old Apr 13, 2005 | 05:33 AM
sithscripter's Avatar
I tapped into the O2 sensor wires at the ECU ... all wiring stays inside the firewall that way.
Power I tapped from the radio harness.
IMO the standard cheapie air-fuel meter does give some valuable qualitative information. It can tell you when you're running in open-loop mode or closed-loop mode, and gives you a general impression of how your ECU and O2 sensor are operating. All for $35 and a few feet of wire.
I realize that's an unpopular opinion on this board, but I seem to spew forth a lot of unpopular opinions on this board.
Old Apr 18, 2005 | 08:27 AM
craE's Avatar
BUMP!
Please someone help me with this some pictures would help too, i just spent 4 hours trying to find the right connections please help?!!?
Old Apr 18, 2005 | 09:06 PM
Help me help this guy ... The tC wiring diagram shows "air/fuel ratio sensor" where one would expect the upstream O2 sensor and the expected voltage at idle is 3.3V (rather than 0 - 1 V). Anyone know the specifics of this sensor?
Old May 14, 2006 | 03:46 PM
MilesMc214's Avatar
Im having trouble too. I was told that it was the blue wire. So I tapped it with a t-tap and now nothing happens.
Old May 17, 2006 | 07:47 PM
bboyizzy's Avatar
yeah great post!!! thanks for info
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
