Info about the demon eye rings by UMNITZA
Last week I ordered demon eye lights from C.C, the package came Friday 9/16 directly from the company. Two of the four rings were sliced in half at center, does anybody know if this is a defect? The kit has no directions, no wiring schematic and no support information further than a Website that my server could not find. (www.umnitza.com)
All the kit consist of are 4 white LED rope rings, a harness, what looks to be two Cap. Discharge or power resister packs, some clips and connectors.
I will have out-of-the-box pics ASAP
Any info you have would be Appreciated, Thanks!!!
Hav eyou tried contacting Umnitza Customer Support ?
info@umnitza.com
Their support team has been absolutely top-notch as far as anything I've run into with my order.
info@umnitza.com
Install instructions are being completed now.
We did our install this weekend. There isn't much to do by way of removing the bumper. It's 8 bolts.
These bumpers are all generic:
1) Remove bolt from fender liner in the wheel well.
2) Remove bolt holding bumper edge just inside peeled back fender liner.
3) Remove all the bolts at the bottom of the bumper
4) Remove 5 pins from the top of the bumper
5) remove bumper.
6) Remove fender bolts holding lights
7) Remove top 2 bolts holding lights
Disconnect as many connections as possible prior to...
9) Pulling light out
10) Cookie sheet for 20 minutes at 200 degrees
11) Remoe 4 screws holding back of light against front of light plexi, gently slide plastic tabs off the front plexi while doing this.
12) Remove inner beauty trim's 2 screws.
13) Place rings at respect corners - 1 dap of glue - less than an teardrop worth at the corners of the rings and the bottom of the ring center.
14) Insert ring botton FIRST, then push gently tops of rings onto bevelled edge of trim piece.
15) Hold for 2-3 minutes (use QUICKGRIP for best results)
16) Wait 10 minutes for glue to fully set.
17) Push wires out the back of high beam and low beams respectively, remove the rubber caps frist, then seal rubber caps OVER the wires.
Put back into oven for 5 minutes, seal up headlight and re-insert all screws.
19) Attach black connectors.
20) Finish Install by reattaching all body parts.
21) Jump for joy, pictures coming shortly.
5) remove bumper.
Thanks much, Umnitza guy
I will be installing them around NOV1 how about the electrical side.... Diagram (schematic) and simple drawing be a breeze..........
Want to make them day and night RL,s
Thanx for the help
Thanx for the help
All right then......forget the wiring diagram I.... Will email you if I have any trouble.... Looks to me like I will be installing them some time around 11/15 installation appears easy
will keep the site posted.
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
umnitza
Jul 25, 2015 07:54 PM
goatbelly
Jul 12, 2015 10:13 AM
