Install a PT546-00140 in a 2006 Scion xB?
Has someone has installed a PT546-00140 in a 2006 Scion xB?
______
______
Last edited by MR_LUV; Jan 28, 2020 at 02:20 AM. Reason: Moved to Correct Forum by Administrator
Here is a list of parts. Depending on your abilities, you can go 100% Plug & Play or, if you have some automotive electrical abilities and experience, you can go the cheaper route and manually find the needed wires and tap / splice as needed. I've done both methods and I strongly suggest the Plug & Play.
The back-up camera kit from Scion is Out of Stock and if you can find it, the seller wants big $$$... I changed mine from the 6 volt OEM to a generic 12 volt camera which gave me the ability to order pretty much any back-up camera from Amazon and made things so much easier. I've installed quite a few of these.
If you have questions.. try to PM me directly.
FYI... Scion Base Audio Wire Harness Kit PT546-00142 | Toyota Genuine Parts PT54600142 . be careful with this FULL KIT.... it's seems Toyota will ship the wrong kit or the kit is poorly made. I've had trouble with a few of these, but others worked no problem?????
I prefer to order things separately.
Metra 40-LX21:
https://www.amazon.com/Metra-40-LX21-Antenna-Adaptor-2009-Up/dp/B003VYTGUC/ref=sr_1_3?keywords=metra%2Bantenna%2Badapter%2BScion&qid=1575833977&s=electronics&sr=1-3&th=1
Antenna adapter female barrel to new style plug in for Pioneer PT0546-00140 $9.99 @ crutchfield.com
OR....
Genuine Scion Accessories PT546-00120-AD HFC Antenna Conversion Cable by $33.00 . This will save you a lot of headaches. Most people install the deck and find that everything works but there's no sound. It's an issue with one wire supplying power to the OEM mini amps on the speakers.
Instead of hunting down the right wire, splicing and etc..This harness makes it Plug & Play.
The link is to Amazon, but they are often sold out. You can Google the part number and find it from other sources:
16 pin Backup Camera Harness (With Reverse Trigger) Item # 7549-T www.autoHarnessHouse.com
DIY for Reverse Trigger wire.... much more work but cheaper... http://autoharnesshouse.com/19867_add.html
*** SAME ITEM ON AMAZON ***
Reverse/Backup Camera Interface Harness for Toyota or Scion by AutoHarnessHouse.com $45.00 . This works... but I suggest doing your research and installing a generic Rear View camera that operates on 12 volts.
The OEM camera setup uses 6 volts and really limits you on camera selection. I suggest this camera, sold by COOLINT for 29.99. It comes with the install kit:
Metra AX-TOYUSB-2 2010-Up Toyota USB Adaptor by $9.00
https://www.amazon.com/Metra-AX-TOYUSB-2-2010-Up-Toyota-Adaptor/dp/B00EAYYQDO/ref=pd_cp_263_1/146-3515601-4930166?_encoding=UTF8&pd_rd_i=B00EAYYQDO&pd_rd_r=13bc7983-74ba-4f13-a07a-f130b1df86d3&pd_rd_w=tlgA5&pd_rd_wg=5UkNm&pf_rd_p=0e5324e1-c848-4872-bbd5-5be6baedf80e&pf_rd_r=AGN2F8Q8MWX0BSXGA7P3&psc=1&refRID=AGN2F8Q8MWX0BSXGA7P3
Car Vehicle Audio USB Cable Adapter Wire Cord 1M 3Ft Length by $8.00
Genuine Scion Accessories PT546-00120-CH Wire Harness by $40.00. This is the harness that adapts the original wiring harness connectors on the older Scion vehicles to the newer style that connect directly to the PT546-00120 Head Unit:
https://www.amazon.com/Genuine-Scion-Accessories-PT546-00120-CH-Harness/dp/B00DF7C4O0/ref=sr_1_1?keywords=genuine+scion+accessories+PT546-00120&qid=1575832211&s=electronics&sr=1-1-catcorr
Genuine Scion Accessories PT546-74120-MC Microphone by $56.99
https://www.amazon.com/Genuine-Scion-Accessories-PT546-74120-MC-Microphone/dp/B00DF7C8AU/ref=sr_1_2?keywords=genuine+scion+accessories+PT546-00120&qid=1575832094&s=electronics&sr=1-2-catcorr
Genuine Scion Accessories PT546-00120-US Wire Harness by . USB adapter to retain the USB / AUX in your center console. I've experimented with cheaper options that worked. Keep in mind, this is simply a USB port so you can get creative:
Option #1
Option #2 .
https://www.amazon.com/Goliton-Female-Retention-Adapter-AX-TOYUSB/dp/B01H1A4L06/ref=pd_cp_263_3/146-3515601-4930166?_encoding=UTF8&pd_rd_i=B01H1A4L06&pd_rd_r=54739d94-09ec-4ada-b5ba-459f2a673081&pd_rd_w=qB3ih&pd_rd_wg=ZzRm6&pf_rd_p=0e5324e1-c848-4872-bbd5-5be6baedf80e&pf_rd_r=DK3Z29J075D7K8B7D6GC&psc=1&refRID=DK3Z29J075D7K8B7D6GC
____
Metra 40-LX21:
OR....
Option #1
Option #2 .
____
