Installed Scion Security...everything works except the horn?
Old Feb 4, 2007 | 07:16 PM
pballplayer18's Avatar
Default Installed Scion Security...everything works except the horn?
I tested everything, but when the alarm is suposed to go off, the hazard lights go off, but the horn doesn't go off. However, if I press the horn it works???? Any suggestions??
Old Feb 5, 2007 | 02:23 AM
tonytc05's Avatar
Did you install the security yourself?
Old Feb 5, 2007 | 02:49 AM
yes
Old Feb 5, 2007 | 02:50 AM
do i need to add a fuse or something???
Old Feb 5, 2007 | 02:57 AM
SquallLHeart's Avatar
you probably installed the wrong one or hooked it up wrong.
Old Feb 5, 2007 | 06:04 PM
i triple checked everything...still can;t figure this thing out
Old Feb 6, 2007 | 12:14 AM
samhain's Avatar
How was the install? Are the insturctions good?
Old Feb 6, 2007 | 01:46 AM
tonytc05's Avatar
There should be a 5A fuse on the security wire harness, check if that is blown. Not sure what it is for. On the car it should be near in the back of the fuse box driver side going up to the speaker.
Old Feb 6, 2007 | 03:26 AM
i meant the part number....
there's two different xB alarms... one for the cars with radio controls.... one without.
that's the only thing that can contribute to a perfect install and not functioning properly, showing the same exact symptoms as you mentioned.
Old Feb 6, 2007 | 07:48 PM
i check and this alarm was for an 05, which i do have, i cheack both fuses in the harness and they are both good...so i still have no idea why eveything else works, but the horn doesn't go off
Old Feb 6, 2007 | 08:08 PM
looking into it now.
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
IrjI619
Dec 21, 2014 05:04 AM
DAHOZZMAN
Dec 16, 2014 06:48 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
cwong1001
Dec 3, 2014 03:30 AM
