Installing components... get rid of the factory tweeters?
I'm slightly confused about this... I'm going to go with a set of Memphis components and I'd like to know if I should disable the factory tweeters in the dash? I was into subs for years but now i'm getting into the other aspects of this hobby and i'm learning as I go. You guys with components, what are you doing with the stock dash speakers?
Absolutely replace the stock tweeters! But more than likely, especially in the xA, you will have to back down your xovers and eq for the tweeters due to the mounting location in the A pillars.
Kind Regards,
Matt
Kind Regards,
Matt
Kind Regards,
Matt
Kind Regards,
Matt
Get rid of the stock tweeters and replace them with the ones that came in your component set.
Kind Regards,
Matt
Kind Regards,
Matt
Juse remember that if you are going for a real SQ install, the Scion tweet locations were made for "weak" tweets to provide great staging appearance. This means that you will have to tweak your tweeter settings (xovers, eq., etc). so that your front staging and imaging are correct, as well as your time alignment. Not sure what type of deck you are running but if you have an Alpine you'll be set for sure.
Kind Regards,
Matt
Kind Regards,
Matt
Kind Regards,
Matt
Kind Regards,
Matt
I have Arc Audio tweeters in my dash, Arc Audio 6.5 inch mids in custom fibreglass kick panels, and Ground Zero co-axials in my front doors. Sounds clean enuff to me.
That's the correct location if you are going for SQ. However, depending upon your musical preferences, you more than likely will have to back down your tweeters as the Focals can become very strong very quick and overpower the rest of your music. It's just a few simple adjustments and you'll be on your way.
Kind Regards,
Matt
Kind Regards,
Matt
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
