interior lights not working big problem or blown fuse?
while tapping into my cubby hole light wires for my boost gauge, i must have touched something together by accident. during the interim of this my gauge cluster and interior back lighting (center console) went out. please tell me this isnt a disaster and that its just a fuse
. i checked all the small fuses, and none of them seem to be blown. does anyone know where the fuse is that might be blown? thank you for your help and i apologize for the lack of searching.
Originally Posted by stick_1NZ
check also under the hood.
Originally Posted by unseen
thank you, i found it. its a 7.5 in the bottom right hand corner in between a 10 and something else, maybe 15.
How's it working now?
Originally Posted by DrBlast33
I have same problem. Its the "TAIL" fuse. Well, I replaced it, and it keeps blowing. Anyone know all the things that this fuse uses, so I can try to find the short?
Scott
nope. The only thing added to my computer is my car computer... but nothing connects to anything but the cigarette lighter and the battery.
Maybe something is pinched by the radio!? I put in a car2aux adapter to the stock radio a few weeks back.
Could a blown bulb be shorted!?
If you have not changed anything recently, I would disconnect the tail lights and try a new fuse,if it does not pop I would inspect the bulbs and sockets to isolate which one, but, if it still pops,I would reconnect the tail lights and I would disconnect the front markers and try again.Repeat with all exterior bulbs.Yes, a bad bulb can be shorted,Don't forget the license lights or the rear side markers too. good luck. There is some other stuff on that fuse but, I would look here first.
if it is the tail circuit, the front markers will still be lit...(not being a smart @ss, I promise). The wife came home one night freaked out because that very loop had blown a fuse. I tore out from the radio to the tail lights and found nothing...except those mini fuses start to get expensive after a while....it was my cupholder LEDs...my wiring, my fault.
Yes, you are right,and page 66 of my factory scion wiring diagram book must be wrong.
scioninla
14
Oct 18, 2003 03:46 AM
2fixA
Scion xA Aero & Exterior
Oct 2, 2003 10:50 PM
sithscripter
9
Sep 26, 2003 05:27 AM
