JDM foglight switch install
Old Sep 24, 2004 | 12:45 PM
tcm_xB's Avatar
You guys have figured out how to wire the switch, but not posting the info. Please post to help others out who are wanting to go with the JDM lamps. Thanks!
Old Sep 24, 2004 | 03:42 PM
turbomx5's Avatar
I posted this earlier in the summer in another thread after I installed my lights.
My switch had 4 pins. Holding it one way there was 1 pin at the top and 3 pins across the bottom.
The 2 pins I used are on the bottom. The one to the far left, and the one in the middle. There was a small space between the 2 pins, where it looks like a pin should be.
The way I determined which 2 pins to use was to attached 2 wires to the terminals on a 9volt battery. I plugged the wires onto the pins and checked for power through the pins with a test light. It took about 5 minutes to figure it out. Be carefull, as 2 of the pins on my switch were constant and not controlled by the switch.
I think the 2 pins that are constant are the single pin and the one directly below it. It's been a few months since the installation, so I could be wrong on this one.
Hope this helps.
Old Sep 27, 2004 | 07:12 PM
Orataro's Avatar
sIcKsCiOnS
The 2 pins I used are on the bottom. The one to the far left, and the one in the middle. There was a small space between the 2 pins, where it looked like a pin should have pin.
I think the 2 pins that are constant are the single pin abd the one directly below it. It's been a few months since the installation, so I could be wrong on this one.
Hope this helps.
It's more help then anyone else has providied.
I too will be installing JDM fog lights in the future.
Thanks.
Old Oct 4, 2004 | 09:24 AM
engr's Avatar
Any pictures of the 2 different switches? U can use a multimeter, set it to resistance to check the contacts. The JDM switches we have for ist have 4 pins as well. 2 for the lights and 2 for the relay. Bascially u need a supply from the tail lamp.
Pin Config
1-Tail Lamp Supply
2-Relay output(coil)
3-Tail lamp Supply to Switch LED
4-Ground
Pin 1 & 2 works as a pair.The purpose of tapping the power from the tail lamp is to ensure the lights will not be left ON by itself. The alram will sound if u forget to turn of the tail lamp when enigne is off.
The pin numbers are just for reference.U will have to figure out which is which with a multimeter.Hope this helps!
Old Nov 30, 2004 | 06:42 PM
jarocho's Avatar
Default You can buy a fog light switch at lowes
They are about $4 and fits and look like really good. Easy to install. It is just a plain black switch. I used this for my JDM fogs. There is another posting somewhere here, but can't find it. Just go to lowes Home Improvement and look in the electrical section.
Old Dec 1, 2004 | 07:35 PM
Orataro's Avatar
sIcKsCiOnS
Originally Posted by dsidescion
I got my JDM fogs from a friend as a gift and they didn't come with a switch or relay. I bought the US ones from Toyota which had to be ordered. They cost 90 bucks for both. If someone needs the part numbers, let me know
So, what's the part #?
Share with everyone please.
Old Dec 1, 2004 | 10:26 PM
jarocho's Avatar
Default I found it
I found the post about the rocker switch that will fit into your scion and can be used for the JDM foglights. I used this switch and it work perfectly. Go to:
https://www.scionlife.com/forums/viewtopic.php?t=29672
Old Dec 2, 2004 | 03:13 AM
windowtint's Avatar
Well we all knew we could just order USDM foglight switches at the dealer's parts counter, but that defeats the purpose of beating your head on the wall while you figure out the JDM wiring pattern. ~~ and now we have JDM switches - lol - as if anyone but us would tell the difference (although the JDM switch lights up - USDM doesn't)
Old Dec 10, 2004 | 12:33 AM
Orataro's Avatar
sIcKsCiOnS
Well, since no one seems to want to post the information reguarding the USDM switch, I'm taking it on my own to find out and post it for everyone to know.
Toyota Part# 84160-38010
I learned that alot of dealers are failing to sell this part so that they can sell you the whole fog light kit.
I'll be installing my JDM fogs this weekend and it should be a "Plug n Play" installation now that I have the USDM switch.
Old Dec 10, 2004 | 12:58 AM
windowtint's Avatar
Sorry Orataro- I woulda given a USDM part number - but I never used one (so, "no help was I says he" ).
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Cadillac15
Jan 29, 2015 07:34 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
