Kenwood NAV Unit Install KNA-G510 for DDX-6019: HELP
Old Apr 30, 2007 | 09:41 PM
BloodySunday's Avatar
Default Kenwood NAV Unit Install KNA-G510 for DDX-6019: HELP
i'm going to install this unit tonight. I spoke with TerribleTed on here who has the same system in his xB and he said that it was a straightforward install. no soldering required, but i'm looking at the wiring harness and it has a total of 4 wires that i need to connect. i don't know where i'm supposed to connect these wires.
there's one for power
ground, parking brake sensor and
"Batt" which i'm assuming is battery.
also, my DVD player is hooked up so i can watch DVD's while in motion. so my parking brake sensor is ground.
does anyone have experience installing this device into their car? i need some help, thanks all.
Old May 1, 2007 | 12:34 AM
TerribleTed's Avatar
For those reading here. Red to switched power. Yellow to unswitched power. Black to ground. The green one you can hook to the parking brake which will disable nav unit routing functions unless stopped with the parking brake applied, OR, hook it to ground and all unit functions will work brake on or not.
Old May 1, 2007 | 03:14 PM
install went smoothly. but i tried mounting the antenna to the front window. couldn't get any satellite reception, so i routed it to the back. now it works fine. i just have to work out the kinks and smooth out the edges on the reinstall of my dash.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
lunchbx05
Dec 11, 2014 06:13 PM
Monkeywrench
Aug 11, 2004 02:55 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
