LED'S in AC outlet
LED'S in AC outlet
Hello,
Does any one no how to do this project of putting LED's into the AC Outlets, how do you run wires and remove the areas to be worked on.
Thanks
Packerfan1962
Thanks
Packerfan1962
I would use twin lead LEDs and run the wires on the outside of the ducts. Then drill holes where the LEDs will stick through into the duct. You will want to use a wide view angle LED (170 degree if possible) so you get good coverage. Then run the wiring through the proper sized load resistors and to a switch somewhere.
The resistors are calculated with the following formula:
R = (Vs - Vl)/I
Where:
R = Resistance in ohms
Vs = Source voltage
Vl = Forward voltage of LED (given in LED data)
I = Forward current rating of LED (also given with the LED data)
This is for designing the system using discreet components, and not with pre made LED/resistor combinations.
R = (Vs - Vl)/I
Where:
Vs = Source voltage
i would like to no this too because i would like to do this and put them vehind the screens of the speakers and in the hatch are where the access port is fo the tail lights on the inside
http://www.yoursciontc.com/forums/in...c=4165&hl=leds
here's an idea and no drilling is involved except of the switch!! i just need to figure out whih wire he used to splice and how?? Hope this helps
SJMiller
09-12-2015 06:33 PM
