Lights when doors are open?
I am sure you could just splice the wires into your dome light wires. That's what I would do unless someone else has a better idea. Just find the fuse that leads to your dome light and tap into that wire. I once did this with a strobe light and it worked fine. I just had the strobe and the dome on the same fuse and had a toggle for the strobe so I could turn it on and off as I pleased. Sorry if wasn't of any help. :?
might be easier to go off your driver side door. the button on the door jam controls the power to the dome light. just take off your lower seat belt panel and splice into it from there, then you can just run the wires under the sill plates and behind the kick panel.
sIcKsCiOnS
page two post by Sid_xBicious
https://www.scionlife.com/forums/vie...6658d8b9f8a32f
imma do that sometime soon......well some time..
its a good thing i remembered that huh?
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
