Luminics Bulbs/ harness Question
Old Sep 2, 2005 | 07:49 PM
z-lite's Avatar
Originally Posted by PRE5TON
I just got the harness and it was very easy to install. Cut the existing harness off, strip some wire, and strip some off of the replacement harness, and either use a tap, or twist tie and electrical tape it. It took me about 20 minutes to do both of them.
Old Sep 3, 2005 | 12:44 PM
Limey's Avatar
Originally Posted by angry_jonnie
Personally I'd rather not cut bits off and splice things - it's never as good as the original... if you know what I mean.
Old Sep 3, 2005 | 02:05 PM
z-lite's Avatar
So you're saying you have it wired to the original harness? The point of getting a new one was to replace the old one. Cutting, stripping, and soldering the 2 wires together is the best procedure in replacing a wiring harness and will work just as good as the original. You may want to use heat shrink tube to protect the exposed wire too.
Old Sep 4, 2005 | 12:56 PM
Limey's Avatar
Sorry I don't think I was very clear.
When it comes to replacing a 'harness' is it just the plastic plug on the end that is being replaced, not the wire?
Old Sep 4, 2005 | 05:00 PM
z-lite's Avatar
right, you're only replacing the plastic connection at the end
Old Sep 4, 2005 | 09:18 PM
Limey's Avatar
Oh, well that's less of an issue then, I'll go do that now.
Old Jan 19, 2006 | 01:11 AM
pdrizzle's Avatar
DeepSouth Scions
So for those people that splice into their oem harness and put a "beefier" harness on the end, what about the original wires? Wouldn't they be too thin to handle the load? What's the point of attaching thicker wires with a better plastic clip on the end if the crappy wires you attach them to could get too hot and get fried? I don't get it.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
