"Need Help on installing a Tach."
Old 09-12-2004, 03:31 PM
noicsXB's Avatar
Default "Need Help on installing a Tach."
Hi, I'm a new owner of a Scion XB and everything is just great except for the the factory tach is so small. I'm plan on installing a stand-alone tach, but not quite sure on how to get the signal for the rpms, could anyone give some advice on this, thanks
noicsXB is offline
Old 09-14-2004, 01:42 AM
DanS's Avatar
Default Re: "Need Help on installing a Tach."
when you choose the tach there will be directions on where to run the wires
DanS is offline
Old 09-15-2004, 10:51 PM
XBCloudMD's Avatar
I am a car audio/alarm installer, and I installed a remote start on my XB, which needs to learn the tach signal. The tach wire I used is Black and located at the data link connector ( OB2 Plug) below the fuse box- pin #9. I believe there are 2 black wires in there, just try both to see which one works, luckily I got the right one on the first try or just use a digital multimeter to test. Hope this helps.
Sam
XBCloudMD is offline
Old 09-16-2004, 03:05 AM
xr4ti's Avatar
u can also get it off of the spedo wires running off of the speedo guage there is a link in the forum for xb wiring.. or u can check the tech section it shows the location
xr4ti is offline
Old 09-16-2004, 04:18 AM
noicsXB's Avatar
thanks a lot...
noicsXB is offline
SuBSiN
03-13-2015 04:02 AM
randomsuper
02-27-2015 01:29 AM
Frustratez
02-26-2015 04:03 PM
ofgarcia
12-22-2014 12:27 AM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: "Need Help on installing a Tach."
