NEED HELP - Running Wire through Firewall (for tC)
Old Oct 18, 2004 | 06:40 AM
nycazn79's Avatar
Default NEED HELP - Running Wire through Firewall (for tC)
I need to run a 8 gauge power wire from my battery through the firewall for my amp. I did a search and found the rubber gasket in the driver's side above the pedals that was mentioned in other posts, however I could not find the other side of it under the hood.
Do you have to remove any parts to get to the hole while under the hood (i.e. air filter box or strutbar) . The rubber gasket seems very tight.....how do you get a wire though it? Any tips/tecquniques would be greatly appreciated.
Old Oct 18, 2004 | 08:38 AM
brownbanana's Avatar
just push it through the rubber gromet, it fits...i fight a 4 gauge power wire in there..i had a friend push the wire from the insidet while i pulled it from under the hood. nothing needed to be moved or removed
Old Oct 18, 2004 | 10:47 AM
TheIcon's Avatar
Default Re: NEED HELP - Running Wire through Firewall (for tC)
Originally Posted by nycazn79
I need to run a 8 gauge power wire from my battery through the firewall for my amp. I did a search and found the rubber gasket in the driver's side above the pedals that was mentioned in other posts, however I would not find the other side of it under the hood.
Keep looking its there Use a flashlight. My friend and I did the same. He pushed and I pulled. We also taped a wire hanger REAL good to it so I had a little something else to pull on. If that fails you may have to make a small little cut in the rubber to push it through. Sometimes it can be a major pain. Just have a friend help.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
randode
44
Jun 29, 2004 04:19 PM
bryanrx7
Jan 1, 2004 09:53 PM
