Need Wiring Diagram for Stock TC Head Unit
Can anyone tell me what wire color does what for the stock radio? I'm adding a speaker in and I can not find a diagram anywhere. Thanks!!
Exactly what maximus said. Make sure you read the installation manual very well, I have a feeling this is your first install
. If you know anyone who has done this before, have them shadow you or lead you in the installation.
As max said, you'll need a line convertor to go from the head unit to the amp.
. If you know anyone who has done this before, have them shadow you or lead you in the installation.As max said, you'll need a line convertor to go from the head unit to the amp.
Originally Posted by maximus96
does the stock head have pre-amp outs? if not why not just tap from the back speakers and use and a line converter?
Best buy has a male and female wiring harness, not only do they have labeled wires they also prevent you form cutting stock wires. Crimp the male and female ends togeather with the rca converter and then plug it in. I did it before i got my new radio and it worked great.
I'm making a very brash assumption here that the xB and tC use the same head unit, therefore the same connectors...
If so, here's the simple schematic for the xB's radio: http://tijil.org/RadioCD.pdf
The drawings of all the connectors is nearly 200K so I won't put it up unless you need it.
Again, that's assuming the same head unit as the stock xB...
wiltonhall
Jun 23, 2025 10:09 PM
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
clickclickw00t
Feb 18, 2015 08:57 PM
