new audio system
Old Jun 30, 2005 | 04:30 PM
Fujiz_xb's Avatar
sIcKsCiOnS
Default new audio system
Due to mishapp with the robbery once and if the insurance claim goes thru I will get the newest models of the system i had
This is the amp
http://www.crutchfield.com/S-lav4McW...0&I=500MRDM105
now i dont remember if i had 2 ohms or 4ohms subs..
but here is the ones i had
http://www.rockfordfosgate.com/produ...r%20Subwoofers
or
wich ones should i get with amp above?
for the components i had this one
http://www.pioneerelectronics.com/pn...786492,00.html
for this one im not to worry about it.
so if you guys can help me out that would be great.
Old Jun 30, 2005 | 04:33 PM
SCI_TC_GUY's Avatar
Fuji, You'll need two dual 2ohm subs so you can wire them in series/parallel and make a 2 ohm load at the amp so the amp will push 1000 watts.....
Old Jun 30, 2005 | 04:37 PM
Fujiz_xb's Avatar
sIcKsCiOnS
so it would be the first set then right?
Old Jun 30, 2005 | 04:45 PM
SCI_TC_GUY's Avatar
yeah....that's correct......
Old Jun 30, 2005 | 04:46 PM
z-lite's Avatar
I'm not an expert but I'm taking a stab at it: You can get two T112D2 and wire them to the amp so that it's 500 watts per sub (2 ohm load on the amp), check wiring diagram #2 at http://www.rockfordfosgate.com/rftec...x=16&image.y=4
Old Jun 30, 2005 | 05:01 PM
SCI_TC_GUY's Avatar
yes, wiring option #2 is indeed series/parallel wiring.....
Fuji, that is the schematic you'll need to follow to get maximum power from the amp.....
ScionLife Editor
Apr 30, 2015 10:40 PM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
Beesh
Jan 9, 2015 06:30 PM
carid
Nov 21, 2014 11:00 AM
fearturtle44
Dec 14, 2003 07:53 PM
