Ordered my system
Old Mar 23, 2005 | 02:08 AM
Scion05BOPxB's Avatar
Default Ordered my system
Alpine CDA-9833
XM Direct Tuner
XM Alpine Smart Adapter
Sony XM-SD46X to power
Polk Audio db6500 6.5 Components (front and rear)
Sony XM-SD61X to power
Polk Audio 124DVC 12" subs (x2)
Gonna run 2ga from battery to dist block. 4ga from block to amps. 12ga speaker wire from the amps to the crossovers and from crossover to components.
Also going to have an AutoPage RS655 (alarm/remote start).
Local shop wanted about $550 to install everything, so I'm going to do it myself.
I'm sure I'll get the mandatory SonySucks posts, and such, but I'm open to all comments. Bring it on.
Old Mar 23, 2005 | 02:14 AM
ScionJohn's Avatar
Now that's what I call "Powered by Sound"! Nice setup....
Old Mar 23, 2005 | 03:14 AM
ScionRI's Avatar
sIcKsCiOnS
um... sony sucks.
why would you buy something that you know sucks?
and i haven't exactly heard rave reviews about polk componenents either.
i'd say your solid choice was with the 9833.
have fun when you upgrade
Old Mar 23, 2005 | 03:43 AM
Piston's Avatar
Actually, the new Sony stuff is good. I am not a sony fan at all, but the Amps that you selected are going to be good. The subs you got are wrong for the amp though. You can get the same sub but not in DVC and the sony amp will put out more power.
The sony amp put out peak power at 2 ohms, and with the subs you commented on will give you a 4 ohm load, or a 1 ohm load and put the amp into protection.
Install is most of what your system will be. Make sure you take your time so you do it right.
Jason
Old Mar 23, 2005 | 11:09 AM
SCI_TC_GUY's Avatar
I ran the xplod 1000x1 at 1 ohm and ran it hard!!! it was actually a pretty good amp.....i don't know anything about the new ones....but the old ones were 1 ohm stable.....
Old Mar 23, 2005 | 11:53 PM
Jason... thanks for the lookout. I guess I've over analysed this thing so much that I forgot some thing that obvious. Gave them a call and changed to the SVC subs instead.
thx again.
Old Mar 24, 2005 | 12:19 AM
tckurt's Avatar
N.G.S.O.
Well the headunit is good... polk is average and sony well isn't the best choice for the main power of your system but your choice...
Old Mar 24, 2005 | 03:16 AM
LavaBox_v1's Avatar
Sony does suck and you should have gotten the CDA-9835 for a couple bucks more ... but other then that ... not to shabby ... let us know how it sounds!
Old Mar 24, 2005 | 04:59 AM
Crutchfield had the 9833 on clearance for $300. Retail on the 9835 was $499.99. Comparison didn't show me another $200 worth of features that I needed.
I'm sure I'll continue to get ragged on about the Sony amps, but some sales reps I talked to said the Sony Escalade at CES had the amps and it sounded pretty good. They are CEA-2006 rated, so the wattage has to be correct. I'm not looking for SPL quality sound, so as long as it sounds a bit better than the stock setup, I'll be happy.
Old Mar 24, 2005 | 05:22 AM
jdub's Avatar
Take some picts when you have everything installed. Good choice, on installing it yourself. It took me an about 30min, to install my system. Not hard at all.
Old Mar 24, 2005 | 06:14 AM
reagulator's Avatar
30 minutes!? thats impressive.
Old Mar 24, 2005 | 11:30 AM
I'm figuring closer to 7-10 days to install everything (working a couple hours a day after work on weekdays).
If you could install everything I listed in my original post in 30 minutes, I not sure if I'd be impressd... or scared to turn it on.
Old Mar 24, 2005 | 12:36 PM
SCI_TC_GUY's Avatar
well.....considering he only has 2 10" subs and one amp......it's very possible for a 30 minute install......
Old Mar 25, 2005 | 07:16 AM
tbone587's Avatar
i was never a big fan of sony amplifiers, but it will give u decent wattage and will definately be better then the stock system, and im sure sounds great to you.
evolving_machine
Oct 21, 2023 01:16 PM
carid
Mar 30, 2015 07:08 AM
cfarrrias
Mar 27, 2015 06:28 PM
carid
Feb 9, 2015 01:49 PM
umnitza
Dec 1, 2014 06:26 PM
