P/R/N/D/2/1 Indicator light M.I.A.
Old Dec 16, 2007 | 03:14 AM
MR_LUV's Avatar
Administrator
Administrator
Default P/R/N/D/2/1 Indicator light M.I.A.
For some reason, I don't have the light on my Center Console indicating the position P/R/N/D/2/1
The funny thing is the Duplicate Indicator light on the dash for the Auto works. All the other
interior lights work, i.e. dome light. And all the exterior lights and beams work.
And the Auto works, just no light.
What happen?
TIA,
Next year,
The LUV MOBILE is Coming!
MR LUV
Old Dec 16, 2007 | 03:41 AM
draxcaliber's Avatar
either the fuse went out, or the light went out. check your fuses to see ifone is out, and then check to see if the light is out underneath.
Old Dec 16, 2007 | 03:46 AM
Metro273's Avatar
It's just a bulb...replace it.
Old Dec 16, 2007 | 04:05 AM
MR_LUV's Avatar
Administrator
Administrator
Hi Metro273,
Any Tips on how to pull the Shift Console cover off
without tearing it up? I've never had to get into that
area and figure maybe one of you ICE guys knows how
to get in there. Or if this problem has happen to someone.
TIA,
Next year,
MR LUV
Old Dec 16, 2007 | 04:19 AM
Metro273's Avatar
^^^I couldn't help you with this one cause I have a 5speed manual trans thus a different way of removing the center console. Someone on here will be glad to tell you how...sorry!
Old Dec 16, 2007 | 05:35 PM
houseofgrafx's Avatar
i noticed mine wasn't illuminated either last week. i was wondering if it ever was. guess i'll go replace the bulb
Old Dec 19, 2007 | 11:56 PM
02CREATION's Avatar
get a manual! hahaha J/K sounds like a bulb or a fuse to get the cover off all you need is small pry tool, careful not to scratch the plastics but just use a small amount of force and it should pop right off. just double check all aroung and make sure there are no screws and you should be all good. good luck
Old Dec 22, 2007 | 02:29 AM
boogi_man's Avatar
you know i picked up a set of pry tools at harbor freight just for stuff like this they are blue and have like 5 to a set for around 5-8 bux
2008ScionXbGold
11
Aug 15, 2016 10:50 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
toyotaisme
Jan 10, 2015 10:24 PM
cid_mcdp
Jan 5, 2015 02:45 PM
dgm458
Scion xD Drivetrain & Power
Dec 7, 2014 05:59 PM
