Painting the Dash Kit
Old Dec 25, 2006 | 12:21 AM
INFINI's Avatar
Default Painting the Dash Kit
Hi,
I hear it's easy to take off the dash kit so I can paint it. Is this true?? If so is it a pain to put back on
Old Dec 25, 2006 | 01:01 AM
TerribleTed's Avatar
It is very easy. Remove ***** from climate control to expose 2 screws, then cneter dash trim snaps off. A clip and a couple screws at the gauge cluster and a few more screws exposed, also 1 each behind the dash speaker grilles, and one thru access square above glovebox,,,whole dash top now comes off in your hand. About 10 mins once you know where the fasteners are. After that it is just a matter of finishing the dash the way you want and snapping it back on .
Old Dec 25, 2006 | 01:29 AM
INFINI's Avatar
Cool! thanks I hope it's just as easy to put back on
Do I need to use a primer or can I just spray it ??
Old Dec 25, 2006 | 01:32 AM
captainlaziness's Avatar
You should probably sand, primer, paint, sand, and paint again if you want a professional look.
Old Dec 25, 2006 | 01:34 AM
INFINI's Avatar
I hate the idea of sanding, but yeah I think so too.
Old Dec 25, 2006 | 01:36 AM
Tell me about it. I wet-sanded my taillights and signal lights for what seemed like days...but it's worth it.
Old Dec 25, 2006 | 01:50 AM
INFINI's Avatar
I love what your did with your taillights!
Old Dec 25, 2006 | 03:09 AM
Yes to make a slick gloss dash you will need to sand then apply adhesion promoter for plastic (bulldog perhaps is a good choice), then prime. After that wet sand with about 320 grit and if not totally smooth reprime and resand, then finally paint and clearcoat. Then for the best look wewtsand and buff the clear
Old Dec 25, 2006 | 04:43 AM
Thank you!
Old Dec 25, 2006 | 09:29 AM
jwaj2002's Avatar
TOCC
well I want a dull finish like whats already there but painted to match the car, I'm just worried about the airbag, the painter at work said for the interior parts we would just mix clear and color together that it would hold up really well
Old Dec 25, 2006 | 11:34 AM
INFINI's Avatar
Yeah I don't want it all shiny either. Heh, maybe I don't have to sand? hehe
Old Dec 25, 2006 | 02:40 PM
Semi-gloss or flat clear over your color will work well also.
Old May 18, 2007 | 07:19 AM
INFINI's Avatar
WOOT WOOT!!!!
Hey I am gonna be posting pics !!! I finally figured out and got the guts to do the rest of the Upper Dash!
I am gonna spray the clear coat tonight before bed and install it in the morning. Post pics then
YAY!
Old May 18, 2007 | 05:54 PM
INFINI's Avatar
If anyone is interested here is a link to the pics.
http://www.infini.bz/fareast/dashpaints/
It's the best paint job I have done so far.
Old May 18, 2007 | 06:08 PM
Sunny's Avatar
That looks great! Very impressive.
Old May 18, 2007 | 06:14 PM
oni424's Avatar
bump to check it out later and not on my crappy work puter
Old May 18, 2007 | 06:50 PM
INFINI's Avatar
Thanks! I am really happy with the results since I can really mess up a simple paint job at times
Old May 18, 2007 | 10:14 PM
Night_Shadows's Avatar
What kind of prep work did you do, if any?
Old May 18, 2007 | 11:26 PM
INFINI's Avatar
Could not have gotten those results without some prep. I sanded a bit with about 300grain (made in china, no number ref) sand paper. Cleaned it off. Did the obvious blue taping for detail, then added the catalog paper to protect the areas from paint.
1 coat of Auto zone primer, waited 20min. Another Primer coat. waited 30min. Then 1 decent coat of color 3Q3 for my car.
Waited 1hr then I put on 1 medium coat of Acrylic clear coat. Waited 25min and laid one more light coat of clear coat.
Left it to dry at around 1:20am. I installed it around 10am
Clear enough?
Old May 18, 2007 | 11:36 PM
Perfect. Thanks
