Possible sound deadening solution?
Originally Posted by chadfo
Originally Posted by jsa3mm
Well, I wanted to get some spray foam for the hatch to spray between the sheet metal. I can't see how else one would sound proof the hatch.
Originally Posted by onionescion
Wow Now I could have read the material sheet wrong on there website but ill check again nope did not think so it is a butyl base unless the make asphalt with butyl it is not aspalt base. but I could be wrong. who realy knows what the put in asphalt. just to let you know that the price is a lot cheaper like less than .60 cents a square foot and weighs less too. So even if the first layer is not the second layer still only csot you less than .60 cents.
But I know what I saw back then and was going off of my experience (I was a college kid and wanted cheap sound deadening).
I searched Polyken and the stuff you are talking about, I'm assuming, is. flashing tape. (pdf file)
Something to note here looking at that product. The operating temperature is up to 200*F. B-quiet Xtreme (asphalt based) is up to 230*F. I had B-quiet extreme in my cavalier. After one summer in Florida, the stuff began to peal and hang all over the place. I'd post pics, but CarDomain is not working right now.
I wouldn't trust applying this stuff on any sloped, vertical, or inverted surface if you live in areas of warm climate.
What about spray expanding foam and then cutting away any excess???
If you want good sound deadening and easy installation without a bunch of fuss and mess you can't go wrong with a pruduct designed specifically for this purpose. Dynamat, RaaMat, Edead and others are good choices. Reseach I did indicates that Butyl based materials are better than asphalt based.
American lung Asociation!!
Quoted from http://www.lungusa.org/site/pp.asp?c=dvLUK9O0E&b=35439
you got me there but i was reading the New york times and there is an artical there on a new study for figerglass check it out. I have worked with the stuff befor for boats and houses the stuff is not good for you can cause lung problems.
I don't have a lot of experience with it but you are right that it can be pretty nasty. I'd never heard anything about a cancer risk with it until you mentioned it. I always heard about asbestos for that.
I put it in paper side out and the rear panel seals up pretty well so other than the movement of the car I don't think I'm too much more at risk than being in my home. Anyone concerned could just seal it up with plastic sheeting like the vapor barriers in the doors. It really does work well.
just so you know when you put the recirculate on in the car on the heater controls you might get particals floating in the car if so you will inhale them. Im just saying watch out you dont want to get a lung disease!!!!!
