Question about wiring LED's ?
I got a question for someone with electrical knowledge. This has nothing to do with my Scion or any Scion for that matter. I am wanting to wire up some LED's to a 9-volt battery and wanting to know how many I can wire up to a nine volt without using resistors or if I have to what size resistors I would need. I am wanting to use the same LED's that come in DEI alarms. I think they are like 3volt LED's. If I were to run 8 of them in series would this be possible off of a 9 volt with or without resistors? Or would I need to run less of them? Any help would be appreciated.
on a 9volt batt. u would be able to run 3LEDS in a series with out a resistor. each LED, if 3volt, takes 3volts from the load. your load which is 9volts would then allow u to run 3 in a series. to run 8 in a series you would need some way to increase the load voltage to 24volts. im not sure if theres a way to do that but ill read some of my elec textbooks....i really shouldnt have slept through elec class...
bootlgr
Jan 26, 2016 01:22 AM
