steering wheel install
Old Sep 2, 2005 | 02:36 AM
TheComputerMan's Avatar
Default steering wheel install
alright fellas,
tommorow i will recieve my much awaited MOMO EVO steering wheel for the xB. does anyone have any experience either first hand or from helping a freind out when installing a steering wheel? is there any good advice to be had to that i dont end up bashing my head through the window within the first couple minutes. :D
i was looking at the steering column and i saw some phillips head screws that could be taken out. is this where i start to install the steering wheel?
any advice is much appreciated. :D
Old Sep 2, 2005 | 08:50 PM
WOW! 40 views and not one reply? does not one person have a custom steering wheel or atleast know how/where to start taking this thing apart?
Old Sep 2, 2005 | 09:18 PM
z-lite's Avatar
Someone's always the guinea pig and I guess it's you. Make sure to take lots of pics :D
Old Sep 2, 2005 | 09:19 PM
TXboxdriver's Avatar
we covered this earlier this month**edit** LAST WEEK in fact
i hate to tell you to search...but...
https://www.scionlife.com/forums/vie...+wheel+adapter
Old Sep 3, 2005 | 03:08 AM
excuse me sir, but that thread said nothing about the way in which to take the steering wheel off. it simply implied what was needed to put the steering wheel on. so before you go on ranting about use the search button, read the thread bro! i was asking if anyone knew of how-to take the steering wheel off and where to start. not what parts are needed to put it on.
thanks for your generosity. :D
Old Sep 3, 2005 | 03:50 AM
grnxb's Avatar
Wish I could help you. I'd bet it will be a challenge since you will have to disconnect/discard the airbag. A mistake, IMO.
Be patient, I'm sure someone here has switched the steering wheel out with something aftermarket. maybe re-title the thread to something like "Have you changed your steering wheel?" or something to that effect.
IDK, but best of luck.
Old Sep 4, 2005 | 06:40 AM
ninjay's Avatar
Before u start make sure u have a hub adapter and the front wheels are straight. I purchased my in Japan, with a MoMo wheel. First disconnect the battery. On the back of the stock steering wheel there are two bolts, requires torx type tool/allenwrench. Mine came with my hub adapter. The horn/airbag should come of after lossening those bolts. Disconnect the two wires that are connected to the air bag/horn. Pull up on the plastic tabs to remove the wires. Now u have to loosen the bolt which attaches the steering wheel to the steering column. Instructions states to use a steering wheel puller to remove wheel after the bolt is removed. I just tapped the wheel with a rubber mallet. After u remove the wheel, ensure u don't move anything on the steering column so ur wheel/hub adapter is installed in the same position as the stock one. FYI, my airbag light stayed on at all times.
Old Sep 5, 2005 | 10:25 PM
GotXa's Avatar
my friend found out the hard way....NEVER use a hammer to get your stock steering wheel off
Old Sep 5, 2005 | 11:06 PM
Romanova's Avatar
Lets stress this ONE MORE TIME! Disconnect the battery! You do NOT want that airbag going off when you f*ck something up.
GL!
Old Sep 6, 2005 | 12:01 AM
sorry for the misunderstanding
and most airbag systems are disabled with the key out
you do not have to disonnect the battery
just be careful what touches the terminals on the airbag
try to store it in an anti-static bag (computer parts)
if yo are gonna keep it
Old Sep 6, 2005 | 03:10 AM
XD40tC's Avatar
So do I have to use my imagination or are you going to tell me what happened to the hammer? Scary stuff there...
Old Sep 6, 2005 | 09:09 PM
GotXa's Avatar
he used a hammer to hit the stock wheel off and he accidently hit the shaft.....needed to replace the steereing colom shaft because he mushroomed the end and couldnt get the stock wheel off.......maybe he is just an idiot
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
armyrockmorales
Dec 28, 2014 10:39 PM
