stereo dash kit
Old May 19, 2005 | 10:27 PM
tC_Scout's Avatar
Default stereo dash kit
i've found many posts regarding replacing the head unit in the dash and which kit to use and so on. the only problem is none seem to be recent. has anyone used these parts in their setup:
http://www.crutchfield.com/S-9qKzvyq...p?i=003TOYK969
http://www.crutchfield.com/S-9qKzvyq...sp?i=120701761
several posts talked about a kit coming out for the tC, but these were posted several months ago. is this the kit they were refering to? this one says that it is adjustable so the door doesn't hit the faceplate.
Old May 20, 2005 | 04:12 PM
tC_Scout's Avatar
posting this again to see if anyone has used the items mentioned above
Old May 20, 2005 | 04:31 PM
SCI_TC_GUY's Avatar
If you look under "reviews" on the crutchfield website for the adapter brackets, you will see that it does fit the tC....
Old May 20, 2005 | 05:47 PM
TheIcon's Avatar
The harness is correct to.
Old May 20, 2005 | 08:46 PM
lalagimp's Avatar
If you order a receiver through them they will give you everything you need including that kit, the wiring and adapters, master sheets that show how to pull apart your particular car model. I just installed mine last Monday.
The scion kit is a universal. some tabs will have to be removed depending on if you're installing on the tC, xA, or xB. The wiring adapter/harness was extremely easy.
Old May 20, 2005 | 08:56 PM
tC_Scout's Avatar
ok, excellent. i'm gonna order them later today and hopefully get them early next week.
airmankevin1
Feb 14, 2018 01:23 PM
clickclickw00t
Feb 18, 2015 08:57 PM
fliggah
Dec 13, 2003 03:11 AM
xvolcomx88
14
Nov 18, 2003 05:29 AM
iglooxb
12
Nov 14, 2003 05:04 AM
