Sub Enclosure Questions (Thirst for Knowledge)
Old Oct 29, 2004 | 02:55 PM
popalock85's Avatar
Default Sub Enclosure Questions (Thirst for Knowledge)
Ok,
When designing and building a box is the displacement of the speaker taken into account? For instance if a sub enclosure has 4.5 cubic foot of air space inside of it before the speaker is placed in the box does the actual speaker reduce the air space when placed in the box. So if the volume displacement of the sub was .5 cubic foot would the box now only have 4.0 cubic foot?
You follow what I am getting at?
Is this an issue or is it irrelevant?
Next,
From what I have read the actual frequency inside of the box can effect the subwoofers performance especially in a perfectly parellel box where the frequencies bounce off of the back of the box and come back directly at the sub. Would a couple of layers of dampening material or liquid solve this problem? Would loading the box with certian angles help this situation?
Finally,
There are neverending debates on the perfect enclosure. I accept that. But my goal here is to gain the knowledge to make whatever enclosure you are looking at getting/making perform at it's maximum potential.
Guidance from the knowledgeable is paramount!
Old Oct 29, 2004 | 03:09 PM
VanillaRice's Avatar
You need to go through and delete one of these posts. No need having two. :D
Old Oct 29, 2004 | 03:20 PM
xBMNx
Guest
Posts: n/a
you are correct if you have a 4.5 cuft box and you have a sub that diplaces .5cuft then the box has a air space of 4cuft
as for the box size...a sealed box the amount of airspace you have will dictate the boxes sweet spot most sealed boxes are arpound 40hz or so thats why lots of people stuff there boxes with polyfil or fiberglass insulation because it changes the properties of the box allowing for deeper bass notes....for a ported box i don't think the amount of airspace matters the only rule of thumb i know is if you build a bigger box (larger than specs call out) the port will be shorter...if its smaller box (smaller than specs call out) the port will be longer...but the bigger the box the deeper you can set your tuning freqency but there is other variables that will affect this as well like the speaker itself the port size and shape (round or slot) the amount of power the sub will recive...also you should keep in mind for a sq ported box you have to keeep in mind the port velocity so you don't get port whistle or port noise...i hope this helps and isn't to confusing
Old Oct 29, 2004 | 03:32 PM
superjeer's Avatar
My subs came with a pamphlet that was very detailed. It had the optimum volume and specified that didn't include the .08 the sub took up (ie, I should add another .08 to the box). It also had another spot that told the total volume in case I could not add, I suppose. This would lead me to think that typically the specs do not account for the displacement of the subs. Also, the polyfill is a very good idea. I usually ripped apart an old pillow and fluffed up the fill and threw some in. It sounded MUCH better than the box I built w/o.
Also, the pamphlet was very specific about port size and length for the ported boxes and gave expected port noise long with the other measurements. I'm sticking to the one with the least port noise (not as deep bass and not the most SPL, but I prefer sealed anyway).
Old Oct 29, 2004 | 07:02 PM
boilerman's Avatar
I have not noticed comments about passive radiators in any of the comments on enclosure construction in auto sound forums that I have read, admittedly few. Are passive radiators no longer in use? I would think that smaller enclosure size would be helpful and understand that smaller enclosure size is an advantage of the passive radiator enclosures.
http://basszone.stryke.com/thunder12.htm
http://www.diysubwoofers.org/prd/
Old Oct 29, 2004 | 07:11 PM
xBMNx
Guest
Posts: n/a
from what i have been told a passive radiator box would have to be huge and the performance that you would get wouldn't be very good
unless your talking about a solobaric with a passive radiator then i could see the box being small
Old Oct 29, 2004 | 08:49 PM
BLACKICE's Avatar
Angles and smoothed surfaces within an enclosure can make a big difference! Passive radiators are in use but not that frequently so I wouldn't put it into my calculations at all.
Volume, cuft of enclosure, port space, size, tuning frequency, resonant frequency of vehicle, amp power, sub motor strength, all of these and more will play a factor in your ultimate accomplishment.
Kind Regards,
Matt
Old Oct 30, 2004 | 10:08 PM
DenZinz's Avatar
Default Re: Sub Enclosure Questions (Thirst for Knowledge)
Originally Posted by popalock85
Ok,
Next,
Finally,
Airspace, depending on the specs.. Crossfire manual will give you an displacement including sub but not including port.
You dont want a perfect sq. or rectangle.[/quote]
Old Oct 30, 2004 | 10:17 PM
hotbox05's Avatar
speaking of poly-fil . anyone know where to get some cheap? and how much would be needed for a 12" sealed hatch style box?
Old Oct 30, 2004 | 10:30 PM
xBMNx
Guest
Posts: n/a
Try walmart or any of your local fabric stores for polyfil sometimes they have it on sale or if you want better find a place or a friend that has so R-19 insulation laying around use it...it has better acoustical properties
Old Oct 31, 2004 | 01:32 PM
BLACKICE's Avatar
There is no exact amount of Polyfill to use. Just keep adding and/or subtracting until you get the exact sound that you are looking for.
Kind Regards,
Matt
Old Nov 18, 2004 | 07:39 PM
popalock85's Avatar
Has anyone ever heard of professionals using concrete encloures?
That sounds insane.....
Old Nov 18, 2004 | 08:20 PM
JLTD's Avatar
There is some infomation about enclosure desing here:
http://www.jlaudio.com/tutorials/boxdesign/index.html
There is information about enclosure types here:
http://www.jlaudio.com/tutorials/magic/index.html
There is information about porting here:
http://www.jlaudio.com/tutorials/ports/index.html
Happy learning! :D
Old Nov 18, 2004 | 09:18 PM
BLACKICE's Avatar
Concrete is used in extreme competition vehicles for the floorboard, dash, etc. The vehicles become trailer queens in this case.
Matt
Old Dec 1, 2004 | 12:04 AM
popalock85's Avatar
So I had a dream last night......
It was about a sub box....
I went to the car audio shop and I asked their opinion on the best materials for box building. Well the installer takes me to the side and he is like "check out this new technology". The box had two layers of wood and I noticed there was like a filling in between them. With that he commented "do you know what that is"? "No" I replied....
"That's play dough"......
Then I woke up.....but I've been thinking and I think I might have to patten that Idea before someone else does.....
I'm fu#^ing crazy man......
Old Dec 1, 2004 | 03:16 PM
grnxb's Avatar
For polyfill, just go to the crafts section in walmart and it is called poly pillow stuffing or something like that. Dirt cheap
Old Dec 1, 2004 | 03:51 PM
JLTD's Avatar
Years ago a company called Dynamat introduced "Dynaboard" which was sheets of double-thick wood with sound-deadening sandwiched in-between.
Old Dec 1, 2004 | 05:21 PM
superjeer's Avatar
poly fill is in pillows, so you might could buy those cheaper or use old ones.
Old Mar 3, 2005 | 08:17 PM
popalock85's Avatar
I guess the important thing is that the box is 100% sealed......
When I get my new box I'm going to check all of the seals and reinforce them if necessary.....
Old Mar 4, 2005 | 04:58 AM
Reign_Man's Avatar
we sell polyfill at walmart, $2 for a big bag that could fill a good sized box for a single 15, maybe 2 12s, and deffinately 2 10s
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
