tC dash warning lights, buzzer, disconnect list
USE at your own discretion, just providing information for those that are curious enough to want to know;)
So far I have only found one alarm(buzzer) on the car. It may be the same one as the key reminder but could be in another location. The key reminder one is in the instrument cluster(combination meter)
Here are some wires you can clip on the cluster wiring harness to disable a few things. All if not will have no effect on circuit operation, just not let the light come on.
Remove the bezel and one screw, remove the cluster, a bit of a tight fit.
With the cluster still facing you remove the harness connector, the release will be facing you.
Turn the connector so you are looking at the inputs, this is a female connector so will have two rows of 20 pins each. The numbering goes from right to left, top to bottom.
1234567891011121314151617181920
21222324252627282930 etc.
If you clip the wires do so with at least an inch remaining incase you need to hook it back up some day.
Some of these should not be clipped but use your own discretion.
Pin 5, Blue, Drivers Seat Belt
Pin 7, Yellow and Key Reminder/Light Reminder, both marked the
Pin 8, Brown same in the manual, will have to experiment here
Pin 13, White ABS
Pin 14, Blue Door Open
Pin 22, Light Green Maint Required
Pin 24, Pink Passenger Seat Belt (can be cut at console as well)
Pin 29, Red SRS, for those that remove the air bags;)
Pin 36, Light Green Tire Pressure Warning
Pin 13, White ABS
I believe there are other ways than cutting wires to stop buzzers and stuff. I dont know for sure because I havent gotten my Tc yet, but this site has a few good things.
http://home.cfl.rr.com/icdedppl/faq.html#a2
I am not saying it covers all of the things that you noted, but either way this is a good site for random stuff.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
missing_image
Feb 7, 2015 07:18 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
TheTripleC
Jan 4, 2015 06:46 PM
