Time for Some Serious A/V Upgrades
Old Jan 3, 2008 | 04:06 AM
HotBox420's Avatar
Default Time for Some Serious A/V Upgrades
So Im upgrading my entertainment... and I've again gone crazy and ordered a million different things and probably have 15+ packages on the way.
What I have now:
~Dual 7" Flip-out DVD Monitor (soon to be moved to the lower flip-storage compartment to be used as a monitor only.): http://www.crutchfield.com/App/Produ...22&i=070VD8181
~Kenwood 1400w Mono Amp: http://www.crutchfield.com/App/Produ...d&i=113KAC9103
~1 -12" Rockford Fosgate T1 Power Sub 2ohm v/c: http://www.crutchfield.com/App/Produ...12&i=575T112D2
Stock speakers
What's on the way:
~ JVC 3.5" DVD Reciever w/ Bluetooth: http://www.crutchfield.com/App/Produ...3&i=105KDAVX33
~ 2 sets of Infinity Kappa Perfect 6.1 Components: http://www.crutchfieldadvisor.com/IS...le.html?page=4
~ 2 more (making 3 total) Rockford Fosgate T1 Power Sub 2ohm v/c: http://www.crutchfield.com/App/Produ...12&i=575T112D2
~ 2 Power Acoustik 9.5 Headrest Monitors:
http://www.buy.com/prod/power-acoust...203018728.html
~ 1 Kenwood 2400w Mono Amp (for 2 of the Subs): http://www.crutchfield.com/S-LyisCFs...px?I=113KACX1R
~ 1 Kenwood 800w 4ch Amp (for the speakers): http://www.crutchfield.com/App/Produ...3&i=113KAC8403
~ 2 - 4.0mfd Power Acoustik Cap's / 0g Amp Kit w/ 3x 4g Dist. Block
~ All Monster 400XLN RCA's Sub / 4ch and Monster 400XLN Sub Wire
~ Fiberglass Triple-12 Sub box from TCCustomz w/ all black carpet:
http://www.tccustomz.com/inc/sdetail/178
So, What do you guys think?
Old Jan 3, 2008 | 02:12 PM
Gothbox's Avatar
sounds like you will have a beast when its all done.
Old Jan 3, 2008 | 07:50 PM
HotBox420's Avatar
i hope so... the only thing im worried about is the box... each sub has a recommended sealed space of 1.5ft.. .and the box is only 2.65 for the 3 subs... so thats almost 2ft too small... how do you think thats going to play out?
Old Jan 3, 2008 | 08:58 PM
dmpsk8's Avatar
that could complicate things. im sure one of these audio gurus could give you more info. and for the record i got my JVC Exad double din + ipod setup for $600. if you havent ordered yet you may wanna shop more
Old Jan 3, 2008 | 09:50 PM
UV7's Avatar
UV7
The low end performance will suffer. Without adequate volume in the enclosure, the subs are not going to have as high an output at lower frequencies. Without the low end, they will sound less like 12s and more like 8s.
There is a pretty cool solution to the problem, however, if you can make it fit. You could buy 3 more of the same 12 and load them isobaric (facing into the existing 12s). Typically, isobaric loads require half the enclosure size of a single woofer. The only downside is less efficiency and a little more complication in mounting and running wires. Since your enclosure is smaller (nearly half) than the recommendation, the isobaric load should increase your bottom end performance dramatically.
Another consideration is the need for a single amplifier to power the subs. Since the enclosure is not divided, you should NOT use more than one amp to power the subs. Doing so could cause early failure of the woofers.
Old Jan 4, 2008 | 12:16 AM
HotBox420's Avatar
Old Jan 4, 2008 | 12:18 AM
HotBox420's Avatar
i actually didn't order anything from crutchfield.. i got the head unit for $421
Old Jan 4, 2008 | 01:31 AM
HotBox420's Avatar
im just going to order a different box...and cancel the other one.. im going to get a mdf triple 12" box with separate sections... then will i have a problem with using the 2 amps for 3 subs?
Old Jan 4, 2008 | 03:19 PM
UV7's Avatar
UV7
No. As long as the enclosure has a separate chamber for each woofer, you will be fine. Just out of habit, I always divide chambers in every enclosure. It is a small extra step, but it leaves many more options for the setup and also makes the enclosure much more rigid, which is always a good thing.
On the new enclosure, try to get something that is tailored specifically to your woofers. If you have to go to a local stereo shop and have one built, then so be it. The price shouldn't be that much different from buying a pre-made enclosure, but the performance differences will most likely be MUCH better. I always hate to see someone buy a pre-made enclosure with some good woofers, only to find that the enclosure wasn't the correct size, which led to poor performance from the woofers or even equipment damage.
my06tc
Jun 25, 2015 12:18 AM
anti_virus347
May 28, 2015 06:01 AM
clickclickw00t
Feb 18, 2015 08:57 PM
reagan9000
Jan 28, 2015 06:20 PM
Scionic
39
Jul 20, 2004 02:46 AM
