variable ground from door lock control relay
Old Jul 21, 2006 | 06:30 PM
cherryBox's Avatar
Default variable ground from door lock control relay
Originally Posted by Tomas
thinking of tapping directly into line 4 (r-y) from d4 for the varial ground to my puddle lamps. Does anyone see any problems with this?
would I need to do anything other than tap in, like a diode, maybe? also thinking it would be good to fuse, but I usually fuse right after tapping power, and wonder where the best location for a fuse would be in this case...one on each end?
I agree to indemnify you =)
Old Jul 21, 2006 | 06:45 PM
Tomas's Avatar
Admin Emeritus
My largest worry (assuming you don't reverse polarities) would be the added load on that single solid-state component.
I don't know how much load your 'puddle lamps' add and I don't know the designed capacity of the controller, but sooner or later if things keep getting added, one will exceed the other and a new $425 controller will be needed.
Old Jul 21, 2006 | 07:38 PM
cherryBox's Avatar
would capacity of the controller be documented in the service manuals?
( the puddle lamps are 10 LEDs connected in series)
Old Jul 21, 2006 | 07:43 PM
Tomas's Avatar
Admin Emeritus
It's not in the manuals I have, but the 'normal' load is under an amp, so I doubt that it's actually designed to handle much more than that...
Tom
DaBlackBox
134
Apr 10, 2022 02:04 PM
mischadoll
Mar 9, 2015 05:48 AM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
Slopoke21m
Dec 4, 2003 07:27 PM
