Vent LED Install
Old Mar 4, 2005 | 02:58 PM
FeeLTHeBuRN's Avatar
Scion Dynasty
Default Vent LED Install
Can anyone help me with a "how to" on how to install LED's into my front four vents? I didn't buy them yet because I want to see if it is something I am able to do before I buy and can't return. Thanks!
Old Mar 4, 2005 | 03:00 PM
Scion Dynasty
just for reference these are the ones I was looking at getting...
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Mar 4, 2005 | 03:14 PM
EVILDAVE's Avatar
Those are the same ones I used . It's kinda tricky to do this first takeout your stereo then get a long dril bit the same size as your LED's them stick it through your vent and drill the whole where you want it . Them put in the LED from behind(don't trust 3M tape on this it won't last real long.I used good old duct tape just a small piece to secure it. Thenon the outer ones take out the speaker and do the same it's easier on these.Then just do your wirring.
Old Mar 4, 2005 | 03:20 PM
Pimpe_Ok's Avatar
Utah Scions
there is no spesific how to but here are some how to on led instalations on other parts of the car same diff. just diff. local
https://www.scionlife.com/forums/viewtopic.php?t=29238
its not that hard i think you should go for it u don't know if u can do somthing tell u try it...right?
hope this helps.
Old Mar 4, 2005 | 03:28 PM
Lonely_Raven's Avatar
I love when my posts dissapear.
Old Mar 4, 2005 | 04:56 PM
Scion Dynasty
how do I take out the stereo...just pull? sorry i never took apart a scion, I did all my other cars though.
Old Mar 4, 2005 | 06:56 PM
DenZinz's Avatar
I did the same exact thing down to the duct tape!! One other thing you can use instead of a drill bit is a R/C car body reamer. The plastic is very thin so a drill bit is kinda overkill.. I used a Uni-bit.
Old Mar 4, 2005 | 08:05 PM
Scion Dynasty
sounds like it is pretty easy...
on a scale of 1-10, 10 being the hardest and 1 being the easiest...how would you rate the difficulty of the install?
Old Mar 4, 2005 | 08:11 PM
Scion Dynasty
It also says no on or off switch required and will not drain the battery...would you suggest just letting them on all the time won't the battery go dead in a day?
Old Mar 4, 2005 | 09:06 PM
Max2k's Avatar
Search for the LEDs in vent topic.
Old Mar 4, 2005 | 10:01 PM
Pimpe_Ok's Avatar
Utah Scions
i would rate it at an overwelming 2.5....... its not that hard just go for it bud. i would sugest buting in a switch though cuz u know if it always on it will eventualy bug the hell out of u.
Old Mar 4, 2005 | 10:03 PM
Scion Dynasty
true plus I don't want to wast the bulb life even though it is like a million hours,
Old Mar 4, 2005 | 10:05 PM
Pimpe_Ok's Avatar
Utah Scions
dubble true bud. So as nike has put it Just Do It!!
Old Mar 5, 2005 | 03:09 AM
Scion Dynasty
thanks for all the advice
Old Mar 5, 2005 | 03:24 AM
engifineer's Avatar
The LEDs will probably only draw between 20 - 80mA depending on the size.. so they would not really hurt the battery unless it was over a very long time..... but I don't like leaving stuff running unnecessarilly (just not clean design to me), so I would just use the ACC power as the source voltage. That way they will turn off with the ignition.
Old Mar 5, 2005 | 03:33 AM
XBman's Avatar
GO FOR IT! cant go wrong for 13 bucks
Old Mar 5, 2005 | 04:27 AM
Max2k's Avatar
If you think about it your car probably won't be on for 100,000 hours, so I wouldn't worry too much about bulb life.
Old Mar 5, 2005 | 05:08 PM
Scion Dynasty
very true...I will probably just wire it to my ACC like engifineer said.
Old Mar 5, 2005 | 05:28 PM
DenZinz's Avatar
Hook it up to your parking light circuit.. whats the point of having it on in the day? If you hook up to acc it will be on everytime you start the car, really it servres no purpose for that.
Old Mar 5, 2005 | 05:32 PM
Scion Dynasty
Oh yea...I didn't think about that. Do the wires fot that run in the same place as the acc ones? or do i have to take my turn signal appart?
