Weird...
Old Nov 6, 2006 | 12:13 PM
Gamecat's Avatar
Default Weird...
So I put in my new GPS this weekend... (pics soon)
Installed the GPS and a PIE Aux input converter so it can play through the stereo...
Everything works fine, but I noticed that now, when I turn off the car the radio seems to lag behind for a second or so before it shuts off.
I'm not sure what's causing this or if I should be worried...
I used a mini add a circuit... not sure if that could somehow cause this???
Old Nov 6, 2006 | 12:47 PM
ZanexGt's Avatar
hmmm, I guessing this is a stock radio?
Also, when you say *lag* ... do you still get audio output from the radio or is it just "lights on, nobody's home"
Post them pics!
Old Nov 6, 2006 | 01:09 PM
Gamecat's Avatar
Yes, stock 05 head unit. (One disc not the 6 disc)
Audio and everything!
Stays on long enough fo me to turn the car off, pull out the key and say "What the -"
Then it goes off...
The only thing I can think of is that the AUX converter draws power in order to signal the HU that it's there? And it's somehow causing this?
Old Nov 6, 2006 | 02:00 PM
mavila66's Avatar
i just noticed that on my box,i use the aux in for my dvd system and i just started to notice that the radio stays on for a few seconds also after the key is switched off,im just using auxillary plug to rca adapter,nothing fancy or electrical.i will try to un plug and see if it goes back to normal?
Old Nov 17, 2006 | 12:51 PM
Gamecat's Avatar
Ok so it no longer does it anymore.
Seems like it stopped after I reset the ECU...
Strange huh?
Old Nov 17, 2006 | 05:16 PM
mavila66's Avatar
mine too ,quit doin it also?????????????????
Old Nov 17, 2006 | 06:24 PM
Gamecat's Avatar
After you reset the ECU or just randomly?
Old Nov 30, 2006 | 04:27 PM
Gamecat's Avatar
Ok update...
So it still does it but only when I have my GPS plugged in but not turned on.
If I unplugg the gps or it's on when I turn the car off, the radio goes off right away.
If it's plugged in but not turned on, the radio takes a second or two to shut off.
Old Nov 30, 2006 | 05:02 PM
Big_Kokujin's Avatar
My aftermarket HU does that...
Old Nov 30, 2006 | 08:19 PM
Pimp_Sling's Avatar
Probably capacitors in the GPS backfeeding through the circuit. If it's really bothersome, maybe install a couple diodes on the cig lighter adapter? That would be my guess without actually seeing the setup.
Mike
Old Nov 30, 2006 | 08:22 PM
Gamecat's Avatar
Doesn't really "bother" me so much.
Just found it odd... And wondering if anyone knew why or if it was about to esplode my HU or something! ;)
Old Nov 30, 2006 | 08:23 PM
You shouldn't be worried about it...i guess its like doing Start/shutdown instead of just holding the power button on a computer
Invertalon
Jul 9, 2012 10:33 PM
scion_040
Scion tC 1G Aero & Exterior
Feb 27, 2010 06:42 AM
rrimportracer
Regional - Pacific South
Oct 13, 2009 07:21 AM
soros151
13
Aug 4, 2009 01:43 AM
Invertalon
13
Mar 18, 2008 03:02 AM
