what speakers fit???
ok some sites say 6.5 front and rear some sites say 51/4 front and 4 in rear
this is all to complicated who out there has used what and what brand and sounds
good with the stock h/u :?
I went with MB Quart Reference 6 1/2 with crossovers in the front & left the rear stock, didnt change them out. I think you can fit either a 5 1/2 or 6 1/2 in the rear. But you definatelt can fit bigger tweeters on the top of the dash if you wanted to. Hope this helps.
There was a thread on this a little while ago.
I'm 99% sure that several people stated the rears are
5 1/4".
Honestly, put your money into really good seperates up
front, with the 6 1/2" in the door, and tweets up on the
dash. Then have your installed put big caps on the *stock*
rear speakers to roll off the bass (they can't handle--which
will be more apparent once you get good speakers up front).
With the money you save from *not* putting new speakers
in the rear, put that towards an amp or sub or better head
unit or something.
The rear are just rear fill, and shouldn't be worried about.
5 1/4".
unit or something.
i have JL VR-650CSi components up front and nothing in the back......but even sitting in back you can't hear the rear speakers.........my mids and highs are blazing loud without being harsh.......i like them very much....
when you take the door panel off, you see the metal bracket that holds the tweeter in it's spot. I took that bracket asm. off and surface mounted the tweeter there.....so it still looks factory.....except for my crossovers on my doors....
where to mount amplifiers in an xB?
I'm ready to install my system, but I was debating whether i should install my amp under the rear seat, or in the storage compartment in the trunk.....where are you guys putting your amps?
how easy is it to take out and put back the rear seat?
pics would be great!!!!
Re: where to mount amplifiers in an xB?
My amp is in the right side storage compartment in the back. Fits well, and all I did was do some cutting on the styrofoam and it just sits there, without complaints. I'll be putting in some fans and will have to cut a couple of holes in the cover for ventilation this summer.
MyNameIsMud
Scion FR-S ICE & Interior
03-04-2015 05:27 PM
clickclickw00t
02-18-2015 08:57 PM
