where to get power
Old Mar 30, 2004 | 11:39 PM
Sid_xBicious's Avatar
Default where to get power
i'm on the process of installing an amp for a sub. i already run a power wire from the battery. my question is where do i tap in to get the system control power.
thanks,
sid
Old Mar 30, 2004 | 11:44 PM
one80ikyu's Avatar
system control? meaning remote wire I am guessing? If so check out this link,
https://www.scionlife.com/tech/elect...ing_colors.php
This link has all the wire coloring codes for the scion.
Hope that helps.
Infiz's Avatar
There's an output from the radio called a remote output. It will send a power signal everytime you turn on the headunit - every amp install kit will come with it - its a long thin wire that you need to run from the headnit to the amp's remote input.
Old Mar 30, 2004 | 11:48 PM
wow thats fast!!!. thanks guys. yeah its the remote relay.
thanks,
sid
Old Mar 30, 2004 | 11:54 PM
more question, looking at the wiring chart, is it the radio 12v, or the radio switch? any link on how to access those?
thanks,
sid
nevermind, found it here: https://www.scionlife.com/forums/viewtopic.php?t=2275
thanks again,
sid
Old Mar 31, 2004 | 06:06 PM
Malaclypse's Avatar
Revolt Imports
DeepSouth Scions
After burning up a fuse hooking the remote start up wrong, I decided to hook it to the lighter. Haven't had any problems since.
Old Nov 12, 2005 | 09:24 AM
moore's Avatar
How exactly are you hooking it into the lighter power source?
-moore
gedster314
14
Nov 17, 2018 02:56 PM
ScionLife Editor
Jun 17, 2015 05:22 PM
ScionLife Editor
Feb 25, 2015 04:40 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
