Who here has an amp rack in their xb?
I'm thinking of building an amp rack to hold my amps and components and i'd like some ideas so if anyone has done this, can you post some pics? Right now i'm probably going to build it to fit in the rear seat foot wells. Thanks.
Never took pictures due to still being a work in progress, i.e. making it look nice.
But I put two Audison amps where the passenger feet would go and had a piece of wood covering them. Could try it with plexi but was too lazy.
I basically bolted down a piece of MDF on top of the carpet the screwed the amp onto that. Then cut out some MDF to make legs to put the cover piece on top of. I used L brackets to hold the legs into place.
Also I put the fuse block and ground under the driver's seat. I recommend a piece from Stinger as the fuse block as it doubles as the ground block too. Unscrew the center console and run the wires across there to get to the passenger side amps.
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
