Wiring question
Old Oct 4, 2004 | 02:06 AM
nycazn79's Avatar
Default Wiring question
I plan on installing a Kenwood DDX7015 into a tC. I already have the Metra wiring harness needed for a Scion and I have been studing the PDF insructions for the Kenwood. All the wires from the Kenwood match the wires already in the car, except the Kenwood wires have 2 yellow battery wires and 2 black ground wires (while the car's harness has only one of each.)
The question is can I do a Y-type connection from the 2 kenwood yellow battery wires into the stock single yellow battery wire connection in the car. Can I also Y-connect the ground wires? If not, I assume one wire stays with the harness and the other goes straight to the battery (or fuse box). And the ground goes to a grounding point.
Here's the pdf if you want to see what I mean (page 107/10
http://akamaipix.crutchfield.com/Man...113DDX7015.PDF
Old Oct 4, 2004 | 02:15 AM
dgHotLava's Avatar
Yes, you do the 'y connection'. put both yellows from the radio harness to the one from the adapter harness.
same deal for the grounds.
Old Oct 4, 2004 | 03:44 AM
nycazn79's Avatar
I forgot to mention that one of the yellow battery wires from the kenwood has an inline 5A fuse in it......will that matter?
Old Oct 4, 2004 | 10:38 AM
dgHotLava's Avatar
That does not matter, just keep the fuse when you make the connection.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
vpkb
12
Oct 8, 2003 04:17 AM
