Xa stereo removal
Anyone know how to remove the stock stereo? or if there are RCA jacks for a sub?
I was going to add a sub to my Xa and was going to do it when I did my DVD player. When I removed the screws to the climate control console and gently pryed the bezel around the stereo it all came out, but it was "stuck" on something, rather than yank harder I thought I'd check the boards. I've seen the removal of an Xb console, but the Xa is different.
Any help?
Any help?
Removing the stereo is easy.....but there are no rca jacks built into the stock stereo.... you could get a line level converter. but to remove the stereo you have to take off the two silver trim pieces on the sides of the ac control.....then there are two screws there and remove your ac control ***** and there are screws there then you can pull the whole dash assembly off....this included the vents to the side of your stereo. the head unit itself only has 4 screws on it 2 on each side.....simple.
