Xb Cigarette Adapter Question.
I want to tap off the cig lighter adapter, but im not sure which wire is the power. black or white? I remember someone saying that black was power, but i couldnt find the post.
Try here:
http://tijil.org/holdfile/Scion%20Re...owerOutlet.pdf
That is the "official word" for the 2004/2005 xB...
In any case when you have two wires, one perceived to be ground, usually the darker wire is ground. In the case where two wires are both the same color, usually one of the wires has a stripe going down it. A dark stripe is usually ground, tera, earth, a light stripe is usually ring/hot. The only way you will ever know for shur is to either spark it (possible fuse blowage), lick it (possible tongue burnage), or meter it. Anyone doing any electrical work should either have a voltage detector (sharp pointy thing with a light on it) or a multimeter (9 bucks). Another benefit of the multimeter is you could tell how much current your accessories are drawing by hooking up the meter in line with the device.
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
pjl52
Aug 13, 2015 02:38 PM
