XB Fog Lights - Too Dim
Old Jul 27, 2005 | 10:43 PM
XtotheByo's Avatar
Default XB Fog Lights - Too Dim
Hola fellow SL friends,
Looking for some brighter Fog light bulbs for my 2005 XB.
I installed some Super Blue Xenon headlights and now the Foggers are just way too Dim and yellowish looking.
Anyone got a hook up on brighter Fog light bulbs ? Maybe just clear covers would help...
Any input would be appreciated. Thanks !
Old Jul 27, 2005 | 10:45 PM
dgHotLava's Avatar
moved...
Old Jul 27, 2005 | 10:48 PM
THE_DON's Avatar
I have MTEC yellow bulbs and I swear they light up the road much better than any white/blue bulb, even silverstars. Regular bulbs just blend in with the headlights, but yellow bulbs really make a difference. You can't really make the fogs "brighter" but you should try a yellow bulb and see the difference.
-THE DON
Old Jul 27, 2005 | 10:56 PM
XtotheByo's Avatar
-THE DON
Awesome, I will try that. Where can I find them ?
Old Jul 27, 2005 | 11:44 PM
2k5_BOP_xB's Avatar
Default Why not try Luminics
XtotheByo
Why not try Luminics I am sure you will be very happy with the results
http://www.luminicsbulbs.com/SCION/xB/2005/
Old Jul 28, 2005 | 12:14 AM
Davestoaster's Avatar
I got a set from JC Whitney. They were 90 watts per side and run at 2800K color temp. They are a touch on the yellow side, but then that is what fogs are supposed to do. Light up the road in bad weather, and the slightly yellow color does just that.
If I remember, they were in the bulb section and they were called "All Weather" bulbs. About $12.00 per side. I love them. About twice a good as the stock bulb that came with the fogs.
Old Jul 28, 2005 | 12:16 AM
bB-aym-y0urs's Avatar
Default Re: Why not try Luminics
Originally Posted by 2k5 BOP xB
XtotheByo
before you try luminics you should read this post https://www.scionlife.com/forums/vie...light=luminics
Old Jul 28, 2005 | 12:38 AM
KevinxB's Avatar
Are you running stock wire harnesses? I'm pretty sure the stock wiring is not rated for such high wattage bulbs.
Old Jul 28, 2005 | 01:13 AM
Yea, it stock. It's OK. With a relay in the system, plus I did'nt even have to up the amperage of the fuse. Those wire will take a lot more than what is needed to power a 90 watt bulb. I'm more worried about melting the plastic bulb housings than I am about the wires.
You mostly have problems with wires on American car lighting systems. They usually are fused together, not a seperate fuse for each side like most Asian and German cars.
I've been playing this high watt bulb game for years with no problems....except on American cars.
Old Jul 28, 2005 | 01:28 AM
KevinxB's Avatar
I see. Are the bulbs tinted or just higher wattage?
Old Jul 28, 2005 | 02:30 AM
The bulbs are both tinted slightly yellow and a higher wattage. Not too yellow, just enough to make a difference on a rain night.
Old Jul 28, 2005 | 02:53 AM
2k5_BOP_xB's Avatar
bB-aym-y0urs
Do you really think the problem was the luminics bulbs and not the harness or some other problem? 3 watts is NOT going to do this. Besides,.....if it were any other brand 3 watts is 3 watts.
the problem here is clearly NOT the bulb manufacture
Old Jul 28, 2005 | 07:59 PM
THE_DON's Avatar
-THE DON
See my sig!
-THE DON
Old Jul 28, 2005 | 08:32 PM
XtotheByo's Avatar
-THE DON
See my sig!
-THE DON
Thanks but I do not see Fog lights, just head lights... Am I just over looking them ?
Old Jul 28, 2005 | 08:58 PM
THE_DON's Avatar
The fogs are 9006 MTEC "golden style" bulbs.
Also try www.automotivelightingUSA.com
-THE DON
Old Jul 29, 2005 | 12:39 AM
-THE DON
Agreed. Those are good bulbs and the right color temp. for fogs.
Old Jul 29, 2005 | 02:52 AM
bB-aym-y0urs
so you are saying it's the harness? i say it's the bulb... i hope it's not the harness because that means that there's a potentiall defect with the stock wiring and it should be recalled. if some one here melts their wiring with other brand of bulbs or may be stock... then it could be the harness. so far it happened to luminics customers. give it a doubt it could be users errors but i doubt those guys are like napoleon dynamite. one member told luminics and they simply told him to put the stock bulbs and take it to the dealer. luminics are hush hush about it. again it happened to luminics customers only...
Old Jul 29, 2005 | 06:20 AM
randomsuper's Avatar
upgrading the wiring harnesses costs like $20.00 for both the headlights and fogs. definately a wise investment if you plan on using a higher wattage bulb.
Old Jul 29, 2005 | 06:48 AM
aireck's Avatar
i have heard the the jdm fogs are brighter than the oem scion fogs.... this is for the xb ofcourse.
is this true???
Old Jul 29, 2005 | 04:22 PM
THE_DON's Avatar
is this true???
Yes. JDM fogs have a reflective inner housing. The US xB fogs have a dull, smoked inner housing. Why? Who knows. But it kills the light output
-THE DON
