XB RS 3.0 Stock Alpine HU questions
Old Aug 6, 2006 | 05:14 AM
deeznutz529's Avatar
Default XB RS 3.0 Stock Alpine HU questions
Has anyone wired an amp to the stock head unit? If so, how did you wire the remote to the hu? I pulled the head unit out with a 12v tester on hand and all that I found was the ignition and constant power outs. Maybe I'm missing something or I just have to install a switch.
Old Aug 30, 2006 | 08:20 AM
hsoj_v's Avatar
I am too having problems wiring up my Tsunami Line Output converter along with the remote wire as well.
I don't know what wires behind the HU to tap into. I tried searching around but everyone seems to only have interest in the Standard Pioneer headunits.
I can't find the RS3.0 Alpine Diagram.
Old Aug 30, 2006 | 12:23 PM
hsoj_v's Avatar
Ok. well... I got everything working.
The Tsunami Line Output Converter is now connected to the rear right speaker and than to the amp. Power is working fine. Everything else fine... Except...
I could tell the problem is coming from the Remote wire cause as soon as I hooked up the power cable the Amp suddenly went on. I hooked up the remote wire to a yellow/blue wire in the back of the "Alpine RS3.0" HU but it doesnt work... I'm going to probably try the grey wire as soon as I recover from 2-3 hours of stress and frustration trying to find all info on this HU. Btw this is my first time dealing with an Audio setup... I'm more of a "Go" than "Show" kind of driver.
Old Aug 30, 2006 | 05:53 PM
Pimp_Sling's Avatar
If you can't find any diagrams online, here is one surefire way. Whip out your trusty DMM. NOT a test light. Leave all your wiring connected. Power up the head unit, switch it to an inactive source, i.e. AUX. Back probe all the wires on all the connectors. Look for battery voltage. 12-14V depending on if car is on or not. Then turn the head unit off. Does the power go away? If so, then you have a switched battery power, which you can tap into and use as a remote. However, since you can't be sure what circuit you are tapping into, I would use a relay to power the remote. This gives you the added benefit of safeguarding your HU should your amp blow.
Mike
Old Aug 30, 2006 | 05:58 PM
hsoj_v's Avatar
Yeah, that seems kinda typical. Thanks for the tip.
Once I find out what wire will work, I'll let everyone else on here know which wire works so no one gets themselfves in a hassle like I did.
Old Sep 2, 2006 | 12:29 AM
hsoj_v's Avatar
Ok, found out that the Remote wire should hookup to the Grey wire on the Blue harness...
Old Sep 4, 2006 | 06:42 AM
onionescion's Avatar
Hey just too let you all know that there will be a problem with the remote line i just installed an amp and a crossover and there was not enough voltage for this youll have to install a relay to turn this on very easy I installed a schosce hi low audio control x over and swiss audio 6 channel amp. Also for you info youll need too use a four or five or 6 channel amp and have to use 2 2 channel converters or one 4 channel converter for amplifing your whole system. I found that if you dont youll not beale too use dual mode for your video. If you have any question please feel free to email me. I have the wire diagrams and relay diagrams.
Old Sep 7, 2006 | 07:04 PM
nakamacotypetuning's Avatar
i'm having the same problem with a stock pioneer hu in my xb and it says to run the converter to the front speakers but it didn't work. can anyone help?
Old Sep 12, 2006 | 01:26 AM
All right I got it. It was the stereo, the head unit it has a frequency adjustment like sci_tc_guy said. (thanks!). I adjusted to 80hz and it was set to 160hz. but it ws still a little bad so I adjusted to 60hz and
bamm! magic***** the sound of beauty. 800W of power. I like to thank every one who helped me get though this. If anyone has any problems with there car let me know I work at Tracy Toyota service tech. yeah yeah i know a tech with problems but we all have our days. haha.
Old Sep 12, 2006 | 02:06 AM
arizonaturbo's Avatar
I just finished my amp & sub install today on my RS3.
This is the unit that www.norcalscion.com sells on eBay. It is easy to install and gives you a set of RCA outputs for a sub!
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Sep 12, 2006 | 05:49 PM
06GreenMonster's Avatar
i took out my radio yesterday and installed my xbox. very easy-plug&play. i got 2 questions. 1.on the bottom of the radio theres a plug like looking thing. anyone have any clue what the hell that is for? also since i installed the xbox my screens are intermittently working. can anyone help me?
Old Sep 16, 2006 | 10:43 AM
no one can help me out here?
Old Sep 19, 2006 | 11:03 PM
I saw it too. It's most likely a programmer's connector.
Old Sep 20, 2006 | 12:52 AM
thanks, ive been racking my brain about that
Old Sep 20, 2006 | 02:25 AM
06xb30's Avatar
Sophisticated Scions
the problem is not the xbox , a lot or RS 3's are having the same problem .
https://www.scionlife.com/forums/viewtopic.php?t=136560
you need to call scion and file a complaint , see above thread there's a #
at the end ..
there are 3 in DFW area that i know have the same problem .. mine work fine at times
if you use just one at a time it always works but turn on both and its a gamble
TotalChaos
13
Feb 4, 2015 10:24 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
cwong1001
Dec 3, 2014 03:30 AM
crocker
Dec 2, 2014 03:44 AM
umnitza
Dec 1, 2014 06:26 PM
