xB Warning Lights: Engine, VSC and TRAC OFF
Yesterday, seemingly random, my Engine, VSC and TRAC OFF lights all came on while I was driving; pretty much simultaneously.
I've seen a few threads about this problem before. The xB is running fine and not idling rough, so I'm ruling out the MAF sensor.
I did just install an amp and sub into my car. I don't believe that is a factor though because i did the installation over 2 weeks. One day I pulled the power cable through the firewall and the car was fine. So probably no damage to other wires. Next week I ran the RCA from the HU. Car was fine. Final week, amp installed and fuse put into the power cable. 2 days later these lights come on.
I noticed that after I took the front seats out, the Airbag light came on. I rechecked the molex connectors under the seat and it went off.
I know there is an ECU reboot by pulling the fuse, I just wanted to see if that solves this problem before I take it to the dealer and they point out at my amp and all that.
Thanks for any help and or personal experiences you can share.
No, no gas. But I can check the cap for secureness.
I'd rather just reset the ECU than take it to one of those places and have to pay $50 for some guy to tell me I need to pay more to have it further inspected.
Besides, if there was a real problem with any of those systems, an ECU reboot wouldn't clear it because the lights should be activated again. Not trying to be a smart @$$, just trying to think it through.
Happened to me twice in a 2 month period, both times it was the "Vapor Lock" Code, I'd say take it to a dealer get the code read, that way if you need something done (more major) you're already there.
No more indicator lights. After starting up my car a few times during my daily commutes the lights went off. If it happens again, its going to the dealer...man that is some weirdness. Car still rides fine!
Please run a search next time before posting a new thread. this has been covered countless times. The present thinking is that because these three lights come on for quite a few different engine codes, you must know the code, before the solution can be identified. Short story: check the codes. you have not posted enough information.
other threads:
https://www.scionlife.com/forums/viewtopic.php?t=149623
https://www.scionlife.com/forums/vie...ngine+vsc+trac
do you see what i mean?
other threads:
Sorry for cluttering the board. I did run a search and didn't find what I wanted immediately.
In the past, the tech section has been kind to me. Perhaps there's a way of classifying all these CEL related threads under a "subthread" of xa/xb ICE?
daniinpitt
Apr 4, 2015 08:07 PM
thefranks5
Mar 25, 2015 08:24 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
