yet another gauge question
Old Jan 21, 2005 | 09:09 PM
jct's Avatar
jct
Default yet another gauge question
i'm planing on getting the 3 major gauge cluster
and and and
1. i'm wondering where does the oil pressure sending unit go/located it
2. the water temp, or the temp sending unit located at
i've seen ppl have that thing where you cut the rad. hose in half to pop it in but i don't remember seen where that web site is at!!!
3. and the volt meter wire up to
i just would like to know of the locations before i have at it
Old Jan 21, 2005 | 09:28 PM
Davestoaster's Avatar
I can tell you from do this sort of mod on other cars, usually the best place for your volt meter, is your cigarette lighter power and ground. That is, if the lighter is switched with the key switch. You don't want it powered at all times. Using the lighter gets you out of running wires directly to the battery and not having to find a hole through the firewall.
Also the oil pressure sender is located below the intake manifold and near the knock sensor. It looks like it might be a pain to get to. You'll probably have to replace it with one that will let you use both the factory idiot light, and the gauge itself. Thats the best way. I haven't found the proper sending unit for oil pressure yet. And good luck getting to it.
The same goes for the water temp. Plus with that, you got to also worry about the little blue light that comes on when cold. Your water temp sender is tied into the ECM and the transmission. So watch out when buying the sending unit for this one.
Old Jan 21, 2005 | 09:40 PM
sithscripter's Avatar
I think Minsk99 did a full gauge install -- search the forums for his posts.
But from my research the most convenient way to do the oil pressure sensor is with the Greddy oil filter adapter or something similar (again several people have used this, search forums).
[/i]
Old Jan 21, 2005 | 09:43 PM
Yea, there is something like that for the water temp also. It fits in line of a radiator hose. I don't know of anything for the oil though. ???
Old Jan 21, 2005 | 09:56 PM
jct's Avatar
jct
make things easier i have the 5spd
Old Jan 21, 2005 | 10:00 PM
jct's Avatar
jct
i probly could get by just using the water and volt
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
mattjk
121
Dec 22, 2004 10:49 AM
xBassist
9
Jan 21, 2004 07:34 PM
