air ride question? first one.
Old May 21, 2005 | 10:09 PM
Spider13's Avatar
The airlift kit comes with 4 corner gauges, I chose not to install them. The problem with a noisy strut isn't in all of them, Ive had 4 and none of mine made noise when install correctly. The airlift kit has alot of issues, the clunk noise isn't very high on my list of things that need to be corrected.
Id be much happier if they redesigned the strut to give you a little negative camber at full drop.
Besides for just a little bit more then airrunner kit you could pay a shop to do a full custom system, and be laid all the way out.
Old May 21, 2005 | 10:41 PM
mrgeorgegarcia's Avatar
sIcKsCiOnS
brianxb what are you running in the front? i am really not happy with the strut in the front, i hate the way the airline is all the way up top, making it difficult to run airlines and the noises i hate, makes you feel unsafe when driving.
Old May 21, 2005 | 11:24 PM
scion1616's Avatar
i believe he is running the eai x-air cylinders. i have a set for sale with machined brackets for 400.00. if you are interested give me a call 251-391-0347.
here is a pic of them installed.
[/b]
Old May 21, 2005 | 11:34 PM
sIcKsCiOnS
did you roll your front fenders?
Old May 21, 2005 | 11:48 PM
scion1616's Avatar
no but i built some aluminum brackets to replace the big plastic one from the factory in the front.
Old May 21, 2005 | 11:53 PM
sIcKsCiOnS
can you explain exactly what you mean about the brackets.
those air struts that you are selling, ho is the installation compared to easystreet
and is there any noise or rattles, and the air hose how did you route it?
Old May 23, 2005 | 01:50 AM
Sittin_Pretti_Box's Avatar
have any of you people ever had experience with air suspension and such before bagging your xb's?
Old May 23, 2005 | 12:37 PM
Spider13's Avatar
I had none, never even really considered doing it before. But its far from rocket science. It's a big job, but nothing is really hard.
Old May 23, 2005 | 05:04 PM
BrianxB's Avatar
I am running the EAI front cylinders and an air accumulator to smooth out the ride. At 80psi it rides great. The airlines are still at the top and you need to run them with enough slack to let it move a bit. My lines are run inside my car. They then go through the firewall into the engine bay, loop around the front of the headlight area and back into the fender well for attachment. This allows play in the lines to move.
Old May 23, 2005 | 09:56 PM
sprslug_182's Avatar
in order to tighten the nut on top without the strut spinning. You need to crank it down with an impact wrench. Sucks, but true. I finally found someone with an air compressor and i got it fixed.
Old May 23, 2005 | 11:24 PM
sIcKsCiOnS
are you using air accumulators in the front and rear and if so how many and what brand, and where are they installed exactly.....sorry for all the questions.
also are you using a camber kit, my front tires are putting pressure on the front bumper when fully dumped.
Old May 25, 2005 | 02:02 PM
LavabB's Avatar
StyleWagons
A guy in our club is having the clunking issue.
I have the easy street kit in the garage, but i'm getting hesitant to use it...
I had a Bagged S10 with a 4 link FBSS etc... It was a pain, I hopped that this kit
would be reliable. I don't want to spend $2200 on air runner, it dosen't look like it even gets that low. I'm frustrated.
-TR
Old May 26, 2005 | 11:44 PM
sIcKsCiOnS
i received the repair kit from airlift today and installed everything back together, and i also cranked the strut bolts allthe way down with an airgun, no more rattles, i just need to find air leaks now, what type of fittings is everyone using on the front struts, i think the push on connectors are loosing air somehow.
Old May 28, 2005 | 02:45 AM
J_A_Trevino's Avatar
[/b]
just curious as to why you are selling these and what are you running now?
hampton1100
May 28, 2015 07:32 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
Godfryness
Jan 2, 2015 11:18 PM
boxzila
34
Jan 12, 2004 03:27 AM
