air ride question for front wheel
Old Nov 16, 2005 | 01:22 PM
lunchbx05's Avatar
Default air ride question for front wheel
i am getting ready to begin running my airlines and make my mounting brackets for compressor and other parts to go under my car.
my main question is how do i get the front wheel to move in with out hitting the fender like i have on so many xbs. i have the fender rolled as much as i can and it looks like it will still hit. i was just wondering what everyone one else has done to make sure this has not happened.
thanks for the help
shawn
Old Nov 16, 2005 | 03:38 PM
RTon20s's Avatar
What wheels are you running? What are the specifications? What tires (size) are you running with them?
The stock wheels should clear without any issue. Every aftermarket wheel has to be looked at individually based on their specifications. For instance a 7.5" wide wheel needs a minimum of +35 offset. If you move up to an 8" wide wheel you need at least +47/+48 offset.
If you have already rolled you fenders, and are still having problems, it is probably time to sell the wheels.
Old Nov 16, 2005 | 05:32 PM
lunchbx05's Avatar
ok it is hitting where the front bumper mounts up to the fender in front of the tire. that is the only place
Old Nov 16, 2005 | 05:39 PM
rampagesd's Avatar
if you went 8" wide w/ a +47/+48 the wheel will hit your suspension. you'll need to change up to a lower offset and not a higher offset.
Old Nov 16, 2005 | 06:14 PM
RTon20s's Avatar
If you run a +35 offset on an 8" wide wheel there is no way you will tuck into the wheel well. Conflicts with suspension won't matter as you will be laying your fender out on your tire.
In order to continue to tuck a wheel as you choose wider and wider wheels you must maintain the "front spacing." Every 1/2" you add in width requires 12.7" more positive offset. Another thing to remember is that the larger diameter your wheel, the less likely you are to get a suspension conflict.
If you start running into conflicts with your suspension, there are two ways to solve it. One is to modify your suspension. This can be difficult, and very cost prohibitive. Your second option is to purchase wheels with proper fitment.
Old Nov 16, 2005 | 06:24 PM
rampagesd's Avatar
easiest way to tuck w/ a 8" wide wheel is adjust the camber. we've done up to a 9.5" wide wheel on a scion and it still tucks. say if you went w/ a 18x8 +40 or higher the wheel will hit lower section of your suspension in the rear and you won't be able to spin the wheels w/ out causing damage.
Old Nov 16, 2005 | 11:37 PM
lunchbx05's Avatar
i have a 7.5 rims size i dont know my offset
Old Nov 17, 2005 | 12:26 AM
Spider13's Avatar
I have 18x7.5 ET 40 that hit hard on the fenders. Mine are stamped 40 but fit more like 35. Ive got a friend that tucks some 18x7.5 ET 40 clean, so it really depends on what wheels you have. If your wheels are between 40-45, most are, your best bet is to get cusco camber plates for the front, and remove the fender/bumper clip for better clearence.
Old Nov 17, 2005 | 01:17 PM
BrianxB's Avatar
correct. my wheels are 7.5 with a +45 and I had to run spacers to have them clear the air cylinders...
Old Nov 17, 2005 | 04:11 PM
dcmcelreath's Avatar
Does anyone know what the offset and width is on the 18" TRD racing harts? I think they are 7.5" wide right? I am planning on doing air ride in about a month, and now i wonder if I need new wheels first??
fur_pig
Mar 20, 2020 04:28 PM
Godfryness
Jan 2, 2015 11:18 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
minter66
Dec 15, 2014 01:45 PM
JDMxB
13
Dec 23, 2003 04:23 AM
