Air Runner - "Maxed Out" @@ more pix 03/21
There is a trick to eleminating vibration transfer to the chassis. You need to order additional isolator bushing for mounting the compressor. And dependnig on the hardware they supply, you may have to run by the hardware store for some longer bolts.
What you have to do is run an isolator bushing on both sides of whatever you mount it to. (like a sandwich.) I was amazed the first time I saw this done. The reduction in noise and vibration transfer is quite significant.
Thanks for the tip.
What bushings do I need to get, just any old bushings?
And do I use the new bushings (on the underside where the compressor is) in addition to the ones that come with the compressor?
Thanks.
Thanks.
Yeah Snicka, RTon20s is a great tip I have sound deadener on the inside and the stand alone frame IMO helps, now maybe after reading RTons20s tip I might do bushings on the frame mounts - couldn't hurt and might help on shock as well
Thanks for all the input... Lucky I haven't finished completely and still have it on jack stands....
Oh yea Snicka... I found condensor/radiator mounts from Cabe Toyota parts department that I used on my o'skool celica oil cooler for shock mounts that would be great for this application I will see if I can find them again, they are heavy duty about 1/2" thick
here I go again another change in the design and layout
it's all good :D
Thanks for the tip!
A friend of mine also told me about some bushings that are used between air cylinders and the upper strut tower that would work well.
I'm gonna try to track those down.
Just a quick follow up on the Air Runner upgrade… as usual I can’t leave well enough alone and now this mod has taken on a new path
:D It was going to be all SS braided line but I found a 37 degree flare tool from Rigid that was affordable and has got me headed in a new direction. I will admit that you will abuse your hands and you will tap into that “Jedi – Zen” level when doing this kind of work. As much as I tried to keep it simple, I got carried away with the flow of the SS hardline and now it’s IMO a frickin piece of art
:D
more to come and all you peeps under 21 stay away from my pain medicine
wow thats sick Dave!!! must have been hell using that Bender... I have the same one and the guys at the shop told meit easier to use a bender that is made for stainless... but it came out looking nuts!!! so how many time did yu have to make those lines before the were perfect..
Now you can come to hawaii to do mines!!!
Originally Posted by rebelMan
Thats awesome man! Can you run hardlines right up to the ports on the bags with the AirRunner kit?
Hawaii Get me a round trip ticket and I am there brah!!!! :D
Originally Posted by fusionscion
i see x's... i wish i can see it though
Randy,
Just found some of your install pic's on another thread, looks bangin can't wait to see the finished fabrication maybe I should move to AZ looks like I a missing all the fun! I still would love to do a full panel 2-door
Most def will be looking for your full install post!
Originally Posted by Toy_xbox
Randy,
Greg S
Jul 21, 2016 07:28 PM
carid
Dec 4, 2014 09:35 AM
Phillip_Injen
53
Jan 17, 2004 01:56 AM
