Which air setup?
Old Apr 7, 2005 | 02:37 PM
xtremeOrange's Avatar
Default Which air setup?
Ok, so my next mod is going to be air, probably sometime next month... However, I'm having a rather difficult time finding a kit that I like. The problem I'm encountering is that most of the kits I see out there only raise the front like 3 - 4", and the back is way up there... I've heard the EAI strutbags will raise it level, but haven't been able to verify. I'd like it to sit pretty level when fully raised, Eric M's white xB is the only one I can use for comparison. Problem with using that setup is that it wasn't a kit...
Basically I'm looking for tips on which kits are capable of actually lifting the front end a good amount, not just nudging it those 3". TIA to all that can help!
Old Apr 7, 2005 | 02:52 PM
Spider13's Avatar
I am not sure which kit will be the best but I can tell you that unmodifed an AirLift Kit doesn't sit level all up or all down. The back can get sky high and sits slightly higher when its down. Swapping the rear shocks could fix this most likely. I don't know much about the EAI kit but it doesn't seem to have much more travel then the Airlift kit.
My airlift kit rides level most of the time because I drive with the front almost full and the rear with alot less air, seems like the more air that is in the back the rougher the ride. Usually just enough air to keep it from bottoming out. Also just a warning that the Airlift the kit is fast, it makes it pretty hard to adjust ride height, it I really need to slow it down some.
Old Apr 7, 2005 | 03:30 PM
squirrel's Avatar
AIRRUNNERS!
Old Apr 7, 2005 | 03:35 PM
JdMBboFSD's Avatar
Originally Posted by squirrel
AIRRUNNERS!
No doubt ...Hands Down ...The Best ....autofashionusa.com ...callem up for more details...
Old Apr 11, 2005 | 12:44 AM
morningman's Avatar
suicidedoors.com
Old Apr 11, 2005 | 12:57 AM
bBism's Avatar
www.fbimini.com talk to phil he and his crew are Great!
Old May 11, 2005 | 07:38 AM
crayonBOX's Avatar
^ ditto on fbi mini & talking to phil, ive seen the kit in use in person, ridden around in 2 setups and its nice even on 18's
Old May 11, 2005 | 03:07 PM
BrianxB's Avatar
Do what I did with my Easystreet stuff... buy 4 pipe plugs and drill 1 tiny tiny tiny hole in the center of it and put it in your dump valve where the air exits. This will really slow down the system upon dump. I can make adjustments on the go all I want.
Old May 11, 2005 | 06:10 PM
rebelMan's Avatar
KAD
is there an actual kit for the scion xB or xA? i want to bag my echo
k1114
43
Mar 1, 2023 03:08 AM
Greg S
Jul 21, 2016 07:28 PM
Beesh
Jan 9, 2015 06:30 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
