cusco/hks problem?
Old Feb 13, 2006 | 08:38 PM
suspended's Avatar
Default cusco/hks problem?
ok, well i recently acquired a set of hks c compact coilovers, well i also just got the cusco plates from MyBox.....problem is, tehy're not fitting onto the HKS, now i've heard of people modifying them to fit, just not sure what that modification is...anyknow know how on earth to get these things to work???!!!
-Thanks
Old Feb 13, 2006 | 09:27 PM
magicmanjk808's Avatar
if you mean the nut from the cusco is not threaded the same as the hks, then it's the same as my easystreet fronts. you need to make a spacer to keep the strut centered and then use the regular nut.
if that isn't the problem, please elaborate.
Old Feb 13, 2006 | 09:29 PM
suspended's Avatar
no, it threads onto there, its hard to explain and i'm not quite sure what the problem is honestly, sounds like one of two things
1) the shaft on the hks is too long for the cusco nut
2) there is nothing holding the spring still on the top
like I said, from what i've heard, there is a way that you have to rig the cusco plate to fit the hks, just not sure what that rig is =(
Old Feb 13, 2006 | 09:30 PM
suspended's Avatar
and from what i've heard, Mark (bboxd) was able to make it fit, also toyxbox (Dave) had them on his HKS setup, but he had the wagon setup, dont' know if that makes a diff. or not =/
Old Feb 13, 2006 | 11:07 PM
i see...
sorry i'm not able to help....
Old Feb 14, 2006 | 08:13 PM
Toy_xbox's Avatar
mine fit fine and the Cusco plates came with spacers...
Old Feb 14, 2006 | 08:16 PM
suspended's Avatar
yeah, i noticed you have the wagon hks, i have the compacts (so does mark), mine came with a spacer, but it still wouldn't work, my coilovers kept making a clunking noise, i think the shaft on the hks compacts are just too long for the cusco bolt and mount, I called mark yesterday and he said what he had to do was take the top hat of the hks apart and run the bottom of the hks hat through the top of the cuscu hat, but you can't go 5 degrees on the camber, you can only do like 1 degree or so =(
Old Feb 14, 2006 | 10:52 PM
Spider13's Avatar
any chance of some pics? That may help out alot.
Old Feb 15, 2006 | 12:56 AM
2tone_xB's Avatar
iono, but good luck man.
Old Feb 15, 2006 | 02:36 PM
Toy_xbox's Avatar
I will be taking my coilovers off in the next couple of days to install the air runner struts I have, I will try and snap some pics of it to see if it will help out. I don't plan on selling them but like they say "Money talks BS walks"
Old Feb 15, 2006 | 02:38 PM
suspended's Avatar
please do snap some pics of it, also, heres my number for when you do, i'm not too easy to reach online
904-226-9219
thank you thank you thank you!!!!
Old Mar 1, 2006 | 06:40 PM
Toy_xbox's Avatar
904-226-9219
Sorry it took so long to get a follow up pic... the following pic is of the Air Runner strut bag it has the same concept asa the HKS WG I could not get a good pick of the HKS because the dust ring and boot block the view the only real difference between the strut bag and the WG is that the spring plate is different both have the spacer(s) in the same position.
Hope this helps...
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
