Form and Function Coilovers for xB/xA installed.
Old Mar 5, 2008 | 11:14 PM
cee_dub2003's Avatar
Default Form and Function Coilovers for xB/xA installed.
We just finished the install on our new Form and Function Coilovers. Here are a few pictures. We are running the 8kg front springs with Custom Weapon-R 400lbs springs in rear.
Old Mar 6, 2008 | 12:46 AM
SuperMario6582's Avatar
nice, looks good man.
Old Mar 6, 2008 | 03:31 AM
swartzautoman's Avatar
wow, you got quite a bit of ajustment to play with
Old Mar 6, 2008 | 03:34 AM
Persocon's Avatar
damn! 8kg/mm fronts 7kg/mm in rear pretty stiff ride. i bet it corners better than a UFO
does the rear shocks have a rebound limit stop doohicky so the torsion beam doesn't expand too much that the rear springs fall out, and is the dampening adjustable?
if yes to both, how much for a pair of rear shocks only?
Old Mar 6, 2008 | 03:39 AM
ryuji16's Avatar
fkn sweet.
Old Mar 6, 2008 | 03:43 AM
the torsion beam will not expand enough for the prings to just fall out.
i just removed my s-techs. with the cars frame up on jack stands and the shocks diconected i still had to jurk on the spring to get them out.
Old Mar 6, 2008 | 03:48 AM
ryuji16's Avatar
question: what did you do with the rear springs that came with the whole setup before you stuck the weapon R springs in there?
might be in the market for a set of rear c/o springs
Old Mar 6, 2008 | 03:50 AM
Persocon's Avatar
in my case it would if i run on my coilover springs without the spring seat and lock, only on the 6 coiled spring only. I'm looking for another shock that will have the lock-in-spring capability
Old Mar 6, 2008 | 01:16 PM
Thumps's Avatar
Slick install, might want to consider some kind of cover for all those exposed threads on the shock body just to keep them from getting caked up with crap.
Old Mar 6, 2008 | 02:49 PM
burstaneurysm's Avatar
Those look mighty nice... what is the min/max drops on those?
Hydryman
Feb 23, 2016 03:35 PM
Threequalseven
Aug 26, 2015 04:24 PM
Forced4
Aug 25, 2015 08:18 PM
Subaru86
Jul 31, 2015 04:33 AM
blackpearlTC
Jul 19, 2015 04:55 PM
