Front Brakes - Help!
Old Aug 12, 2006 | 06:51 PM
kidkamel's Avatar
Default Front Brakes - Help!
MODs I wasn't sure where to post this other than here. If you need to move it to the correct locatoin please do. *********
Well my front brakes have been squealing when I brake. It's been a year an half and about 12k since I had them replaced and I figured it was time to have them replaced. I jacked up the car and took off the wheels and the pads look like they were brand new.
So now I'm confused why would they squeal? I took the assembly apart clean every area I can with brake cleaner and put it all back together. Drive it around I'm fine. Later that evening they start up again. I got my pads from Napa Parts and they are Ceramix. When I replaced my pads before I always have my rotors resurface.
What am I missing? HELP!!!
Old Aug 12, 2006 | 08:42 PM
bB2NER's Avatar
Music City Scions
With FWD vehicles it's always cheap insurance to replace the rotors with new whenever you do new pads. They are too thin to have cut and reuse.
Do the new pads have that stainless piece on the backside. If not that may be why they squeal. Also stick with good quality semi metallic pads. For even better braking go with green stuff pads.
Old Aug 12, 2006 | 09:49 PM
xA_Factor's Avatar
If the pads are good, then it sounds like you have some brake dust build-up. Pads are semi-metallic and the dust can cause squeeking sometimes.
Take your car to a self-serve car wash. Use the high pressure wand to blow out the calipers. Don't worry, you won't hurt anything.
I bet this helps.
Old Aug 12, 2006 | 10:44 PM
hayalex6's Avatar
btw, there's no E in B-R-A-K-E
Old Aug 12, 2006 | 10:54 PM
xA_Factor's Avatar
B-R-A-K-E <--- What's that?
J/K
You're right, it's "brake" not "break".
kidkamel....you listening?
Old Aug 13, 2006 | 02:04 AM
bB2NER's Avatar
Music City Scions
True dat but he said the pads were new and had the rotors turned.
Old Aug 13, 2006 | 02:17 AM
xA_Factor's Avatar
Yeah...that's what I was saying...."if the pads are good"....which he said they were, then he needs to look at other possibilities....like brake dust squeel.
Now get off me chump!!
Old Aug 13, 2006 | 02:22 AM
bB2NER's Avatar
Music City Scions
But "NEW" pads wouldn't have brake dust build up is all I'm trying to say. Why is that hard to understand Bro? And how did you use that smiley??? It's not in the list.
Old Aug 13, 2006 | 02:45 AM
xA_Factor's Avatar
Default Re: Front Breaks - Help!
Originally Posted by kidkamel
It's been a year an half and about 12k since I had them replaced.....
I have lots of "extra" smilies.
Old Aug 13, 2006 | 03:09 AM
bB2NER's Avatar
Music City Scions
My Bad. That's what I get for reading these things this late at night. Sorry I suck. And You suck! I want more smilies too
Old Aug 13, 2006 | 04:33 AM
xA_Factor's Avatar
Old Aug 13, 2006 | 04:36 AM
bB2NER's Avatar
Music City Scions
So that's how it's gonna be? I got it figured out now anyhow.
Old Aug 17, 2006 | 03:14 AM
kidkamel's Avatar
Thanks for the spelling correction.
I will try the high pressure wash but I cleaned them in and out. I also spoke to Napa and they said sometimes they get a bad batch, which is not a good thing to hear, so I'm planning on picking up a new set. They also said I could replace them with a different set. Hopefully the new set will be better.
Sorry it took so long to reply to everyone and thank you again for everything.
Kidkamel
evolving_machine
Oct 21, 2023 01:16 PM
toyotaisme
Jan 10, 2015 10:24 PM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
