front camber
Old Dec 17, 2006 | 11:22 PM
wanachat15's Avatar
Default front camber
does the camber plates really work? the one that came with my D2 coilovers works but i don't really notice it. so i was just wondering if other camber plate will give it a box extreme camber or just enough. and slamming the box from zero camber suppose to camber it automaticlly right? but my gets caster and alway wear the outside out. so instead of camber i get caster. so to get a zero camber when i align it. i have to negative camber it i think. is it just me or what?
people that has bought from bbist? how do you buy from them cuz i never before. i checked them out and see that they don't have a checkout, so how will they know what product i want?
Old Dec 17, 2006 | 11:24 PM
Big_Bird's Avatar
i got about a degree and a half from lowering my box, i wanna get proper camber plates though
Old Dec 17, 2006 | 11:34 PM
wanachat15's Avatar
i don't think i even got that. i think it went the opposite way. cuz i when dropping it, the wheels will toe out, which will cause inside wear. so i fixed that by getting it align with zero camber on the camber plate. and still i'm getting a a lot of wear. so is my camber plate wrong which i doubt or what?
Old Dec 17, 2006 | 11:38 PM
JDMJim's Avatar
don't nitce the camber. try an alignment shop and then move the camber adjuster. I'm at -1.27 for now. It's my toe that I worry about since I'm on air.
Old Dec 17, 2006 | 11:48 PM
wanachat15's Avatar
had that problem too. when i was experimenting. dropping and raising it constanly. toe changes. so i don't want to keep paying for alignments. this also brings up another topic. what you guys think about the DIY alignment kits?
Old Dec 18, 2006 | 12:08 AM
xA_Factor's Avatar
The easiest way to get more camber adjustment is to install a set of "crash bolts". This bolt replaces one of the lower strut bolts (usually the top one) and is more narrow. This allows for some decent camber adjustment. Plus they're cheap. You can get them from most good alignment shops. Some dealerships carry them too.
Negative camber = top of tire leaning in. Good for handling.
Postive camber = top of tire leaning out. Not really good for anything.
Neutral camber = wheel/tire are standing straight up. Good for straight-line braking and acceleration.
Old Dec 20, 2006 | 06:35 AM
bB2NER's Avatar
Music City Scions
Exactly right. I don't get how those plates are supposed to work being that high up. Just get the caster bolts for the lower strut mounting and move the camber back like that.
When lowered, which way does the top of the tire want to go? In or out. This would help when I put my spring in later. Thanks!
Old Dec 20, 2006 | 07:12 AM
hotbox05's Avatar
my ksport camber plates do major camber.
Old Dec 20, 2006 | 09:31 AM
wanachat15's Avatar
really? ksport? i was looking at the GT coilover set. looks awsome. was thinking of getting them.
any kine caster/crash bolts or gotta be specific?
Old Dec 20, 2006 | 10:21 AM
hotbox05's Avatar
kine?
the lower camber bolts are almost universal nowadays.
caster. eh I wouldn;t adjust it. just gotta watch for toe.
Old Dec 20, 2006 | 10:34 AM
bB2NER's Avatar
Music City Scions
How much toe in will I get with 1.5 inch drop on average? Might have to make slight adjustment after the install.
Old Dec 20, 2006 | 10:40 AM
hotbox05's Avatar
could be lucky and get nada could be unlucky and get a lot. i've never done an xb and have it go into the red as far as alignment specs go.
Old Dec 20, 2006 | 10:42 AM
bB2NER's Avatar
Music City Scions
Cool, I'll just check it before and after and see if it goes outta spec. Tanks mang!
Old Dec 20, 2006 | 09:00 PM
wanachat15's Avatar
yea when i had my 1.5 s-techs. i didn't notice any change in the alignment or camber. there was no major tire ware that i notice. i think it's to little to affect anything.
Old Dec 20, 2006 | 09:54 PM
BrianxB's Avatar
D2 coilovers are weird like that. My car actually had to have the camber plates maxed out to get it back into spec for camber. I have about -1 degree in the front on each side. You can add bolts for adjustment if you want more.
Old Dec 21, 2006 | 01:26 AM
wanachat15's Avatar
same here i had to almost max it out to bring it baq into specs.
Old Dec 21, 2006 | 04:26 AM
hotbox05's Avatar
with cusco camber plates and my ksports to be in the green. one side is maxed out the other is almost perfectly in the middle. LOL
Old Dec 21, 2006 | 09:50 AM
wanachat15's Avatar
are you using two different plates? or thats just how your ride is?
Old Dec 21, 2006 | 11:25 AM
hotbox05's Avatar
all cars with cusco plates that I have seen do that. and the plates on my ksports align the same way.
Old Mar 7, 2007 | 03:04 PM
whipple81's Avatar
I am installing the KSports this weekend, and one of my biggest questions was the camber settings. I am running the stock wheel with some 215's -- any body wanna ballpark a camber angle for me? Or does anyone have a DIY resource for camber adjustment?
Hotbox, I see you are all about the ksport's -- any ideas?
scionhawaii
13
Jun 19, 2015 03:59 PM
HeyyJose
Mar 11, 2015 02:15 PM
jcraff3
Feb 20, 2015 11:41 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
