Modified spindles and lowers for camber Good for -12 ?????????
Old Aug 1, 2022 | 07:50 PM
allynxbell's Avatar
Lightbulb Modified spindles and lowers for camber Good for -12 ?????????
hey guys I'm allyn from Cali. im a new member but not at all new to the site. I have a couple questions that I was hoping I could get some answers to. i was on Facebook marketplace looking for parts and stumbled across a listing titled 2006 Scion Xb Aftermarket And Modified Parts. Modified spindles and lowers for camber Good for -12 is what is in the description. i have never seen or heard of this being done I'm not against doing things ourselves or doing custom work so i wanted to hear what you all thought of these . i was always told that cast was very difficult to weld. is this common ??? I'm not at all bashing this mans work but this does intrigue me.
Old Aug 2, 2022 | 01:05 AM
MileHightC's Avatar
Super Moderator
SuperMod
Unless I know who welded them or there was the option to return them I'd be wary...for the very reason you stated. Suspension items aren't something I'd want to 'roll the dice' on the quality of the work.
Old Aug 2, 2022 | 05:11 AM
DannoXYZ's Avatar
Moderator
Moderator
That's NOT good spot to cut & weld!!! High load & torque there. Would be better to chop and weld on line parallel to mounting holes. Lots more surface area to spread load and lower torque moment there too.
Not to mention those welds look like crap!!! Here's how to do multi-layer weld in high-stress area.
Besides, if you want that much camber, just slot mounting holes in strut.
Old Aug 2, 2022 | 12:40 PM
RichBinAZ's Avatar
Depends how much carbon is in the casting, needs to be low - which is difficult to detect for the average guy.
Welded suspension parts? No.
That sprocket is toast BTW. The welding is nice, looks like a machine did it.
Old Aug 4, 2022 | 11:19 PM
DannoXYZ's Avatar
Moderator
Moderator
Thanks! Hand-welded, technique is known as "lay-wire"
Needed offset sprocket on my VFR for wider wheels.
Practiced on old sprocket to start.
Old Aug 24, 2022 | 04:55 PM
MPRZ's Avatar
Oh, holy crap. I hope you didn't end up installing those, because they are a disaster waiting to happen.
Steering knuckles (or spindles or whatever you want to call them) are forged, not cast. Forged steel is incredibly difficult to weld safely and should only be entrusted to welders with a lot of experience. My recommendation is to cut your losses and toss those straight into the trash.
richdog
Aug 7, 2013 09:17 AM
Sciontuner
15
Jun 30, 2010 02:49 PM
CDogbert
Jun 3, 2010 05:35 PM
stick_1NZ
14
Feb 19, 2008 05:52 PM
avengylene
Jun 22, 2005 08:54 AM
