need extended front studs large spacer small stud ?
Old Mar 14, 2006 | 08:27 PM
Capt_pooty's Avatar
StyleWagons
Default need extended front studs large spacer small stud ?
need your help fellas and ladies if there are any...lol... hey i neeed extended studs for my front end i have cylinders up front and im banging my wheel so if you al have the part # i need the ones that are 1/2 inch longer than stock that would be great.. the backs are the same as the front.. please help... the spacer i need is to thick for the stock studs so thats why i need them...... thanks for the help.........
Old Mar 15, 2006 | 06:35 AM
crayonBOX's Avatar
the toyota tundra lug studs are 1/4" or slightly larger - but that's the best my parts dep. could check on - i suggest hitting up your locol parts store and pulling a stock stud from their rack then asking them to compare it size wise to other boxes
tedious, but works
Old Mar 15, 2006 | 02:58 PM
Capt_pooty's Avatar
StyleWagons
problem is they dont have them in stock no one does.......gggrrrill try the tundra ones but i heard they are larger in girth...so i dont know what to do
Old Mar 15, 2006 | 03:30 PM
Endless4LIFE's Avatar
I have 25mm studded spacers for the xA/B if you're interested in those. Your other option would be to get H&R Spacers as they will come with studs. What size spacer are you using?
Rishie
Old Mar 15, 2006 | 03:46 PM
Capt_pooty's Avatar
StyleWagons
i am in contact with H&R right now.. the only bad thing is they dont sell the stud with the spacer its all seperate.... GGGGRRRRR.. but they have the studs i need just need to know the length in MM what the stock one is and ten order it a half inch longer in MM which is 14 MM so i need a 14MM longer than a stock stud thanks if you can help.......
Old Mar 15, 2006 | 03:52 PM
So you're taken care of then right? Since you're in contact with HR? If you need a vendor to purchase these for you please send me email to sales@autornd.com with your location. I'll see what I can do. You'll need to tell me the length of your studs tho. Or rather how long you want them to be.
Thanks, Rishie
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
BManAmericae
Jan 18, 2015 12:17 PM
TheRedBox
Feb 3, 2005 02:00 PM
Docofmind
Nov 11, 2003 07:09 PM
