newbie will this fit ?
Old Feb 16, 2007 | 01:47 AM
fiveoverr's Avatar
Default newbie will this fit ?
looking into gettin tein h techs 1inch drop springs, sport max 501s 15x8 +15 offset on 225/50/15s any comments or opinions. also maybe a 10mm rear shim. thanks.
Old Feb 16, 2007 | 02:37 AM
smoke20's Avatar
You might get some rubbing with the 10mm spacers. I haven't seen anyone use such a wide tire on them either.
Old Feb 16, 2007 | 02:44 AM
brownKIDDnate's Avatar
damn using a 10 mm rear shim is pushin it with 15+ offset and a 225, and h techs could still have you riding high, coilovers you can adjust the height to make it look right
Old Feb 16, 2007 | 03:42 PM
ChampionJeep's Avatar
Go with a 5 mm spacer and for a tire 195/50. You should be alright. With the h techs you will still have alot of wheel well gap.
Old Feb 16, 2007 | 09:12 PM
fiveoverr's Avatar
i dont want the stretched look or knowing i have a tire to narrow for the wheel. i think the added gap of the h techs will help with the wider tire. ne 1 else?
Old Feb 18, 2007 | 02:28 PM
fiveoverr's Avatar
bump
Old Feb 18, 2007 | 10:53 PM
bB2NER's Avatar
Music City Scions
You should be fine just forget the rear spacers.
Old Feb 18, 2007 | 11:41 PM
jambo1's Avatar
that's the exact set up I'm thinking about... would the tire height of the 225/50/15 be the same as stock regarding speedometer? Has anybody actually tried 225s on the 501s? Would I have to roll the fenders?
Old Feb 19, 2007 | 12:38 AM
bB2NER's Avatar
Music City Scions
Speedo wise you'll be fine. I think they will stick out too far. Maybe a 30mm offset up front and 15mm out back to keep them looking right?
Old Feb 19, 2007 | 07:22 PM
fiveoverr's Avatar
just stagger the tires 205 in the front and 225 in the rear. i think ur right tho on the front tires sticking out. hum.... i guess stretched 205s it is.
Old Feb 19, 2007 | 08:13 PM
jambo1's Avatar
this is going to be a stupid question, but if you put different size on the back, you can't rotate them can you? Don't radials have to be rotated front to back... not left to right, so that they maintain the same direction? Also, what happens to the ride quality with stretched tires? 205s on an 8" rim would be a pretty minimal stretch, I wouldn't think it would make much difference.
Old Feb 19, 2007 | 08:26 PM
bB2NER's Avatar
Music City Scions
As long as you had uni-directional tires you could just rotate them from side to side and keep the more offset wheels on the back. It would also look better with the deeper dish wheels on the rear.
Old Feb 19, 2007 | 11:46 PM
fiveoverr's Avatar
so what do u think then of the same +15 offset wheel front and back on 205/55s. still use a 10mm rear spacer?
Old Feb 20, 2007 | 03:40 AM
bB2NER's Avatar
Music City Scions
15 offset up front will stick out too far. use like 35 offset upfront and 15 for the rear without the need of spacers.
Old Feb 20, 2007 | 03:44 AM
smoke20's Avatar
Those 501s sit pretty flush up front with a +15 I wouldn't call it sticking out. It's still too far out for my tastes though
Old Feb 20, 2007 | 07:40 PM
fiveoverr's Avatar
ive seen a few pics of +15 in front and +5 in rear with spacers i like the flush look. but wanted to stay away from stretching. owell. cant win em all
Old Feb 20, 2007 | 07:58 PM
ElChupacabra's Avatar
Im running 225 in the rear on a 16x7 Rota Sub-Zero with 40offset. No rubbing but your 15 offset might become an issue. Im also lowered on TEIN S-Techs....
Old Feb 20, 2007 | 09:49 PM
fiveoverr's Avatar
thanks
SpaceCaptain
May 11, 2015 06:24 PM
ep3rr
Mar 27, 2015 06:10 PM
Beesh
Jan 9, 2015 06:30 PM
scotttie17522
Regional - Northeast
Dec 12, 2014 12:33 AM
tC6M
Nov 26, 2014 06:44 PM
